Gen 2 or Gen 3?
Discussion in 'Gen 2 Prius Main Forum' started by SteveLee, Mar 29, 2016.
  1. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    So I'm still looking to replace my totaled 05. I don't think I want to look for older than an 08 and there is the option of moving to the Gen 3. My question is, would you stay with a later model Gen 2 or move into the Gen 3 and why?
    I drive 25-30k a year.
    #1 SteveLee, Mar 29, 2016
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    One advantage of having one of the last of a generation or model is that all the bugs have been ironed out, all the developement and improvements have been done, and you're not the "guinea-pig" for a new, untested, latest fad! (IMNSHO) Good luck! :)
    prius_power likes this.
  3. prius_power
    prius_power Junior Member
    57
    16
    Ohio
  4. Mendel Leisk
    42,347
    @prius_power I seriously doubt this is anything more than a self-fulfilling rumour.
    #4 Mendel Leisk, Mar 29, 2016
    Ozark Man likes this.
  5. prius_power
    57
    16
    Ohio
    You're likely right, but it's enough to scare me away. I read that a person on reddit in /r/prius had an oil consumption issue on their 2010. I googled it, and there are some reports of it. Googled it for the 2011, and there was nothing. Don't get me wrong though, the numbers of 2010 Prii with that issue is also still quite low. I did test drive a 2010 with over 250k miles and it was fine.
  6. Mendel Leisk
    42,347
    Can only speak for ours, oil consumption is eerily absent, none. Only 60,000 kms, changed every 6 months. Manufactured Aug '09, purchased (new) Nov '10.
    But yeah, who knows, there might have been a bad batch.
  7. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I went backwards so to speak. Had a 2010 and just recently got mint '06. If I were you, I'd go for a Gen 3 for the more responsive drivetrain (gen2 feels like it's in ECO mode all the time) and numerous updates and better screens. Although the G2 feels more spacious up front without the flying bridge, we have no use for that empty space and I prefer the shifter position on the G3 better.
    When I was looking for a decent, low miles G2 (for the kids to drive), I found slim pickings; most have a tons of miles and the original battery.
    GOOD LUCK!
  8. waynedubjay
    waynedubjay Junior Member
    16
    all ova
    If you're buying something like a gen2 make sure it's 2007-2009, as the warranty on the others will soon expire or already have. So, unless you're paying 4-5k for a gen2 with decent miles(less than 150k), i'd go with a gen3. Because a new battery will cost you 2-3k, something that you could of just spent upfront on a lower mileage gen3 without the hassle of going to the mechanic or DIY.
  9. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    There are pros and cons for each. I'm personally most drawn to the Gen 2, for the styling and better off-road ability (less distance between the wheels, slightly higher off the ground). One thing I do respect the Gen 3 for is being completely belt-less. The Gen 3 engine coolant pump is electric rather than mechanical, so the serpentine belt was omitted. Leaks also do not seem to be a problem with the Gen 3 electric pump.
    I personally wish the Gen 3 had retained the 1.5 engine rather than going to the 1.8 (I always prefer smaller engines), but the upside of the 1.8 is better power when the traction pack charge level reaches the minimum (happens frequently in the mountains).
    With the amount that you drive, I would probably focus on finding the lowest-mile example in your price range, regardless of generation. I'm not overly concerned with the HV pack, myself. The worry for me would be the issues associated with high chassis miles (bearings, suspension, wear of other components).
  10. Mendel Leisk
    42,347
    That reminds me: no valve clearance adjustment on 3rd gen; clearance is hydraulically adjusted. And second gen adjustment is shim/bucket style. It's a relatively stable system, compared to screw adjustment, but if it ever needs doing a bit of a nightmare.
    Did anyone mention the second gen bladder gas tank?
  11. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Interesting on the valve adjustment--I wasn't aware of that.
    I don't consider the fuel bladder a factor, myself. I've never had any complaints with it, and like the idea of reducing fume production.
  12. SteveLee
    645
    180
    North Carolina
    I
    All good points, thanks guys. So if a Prius was originally sold in California and is now in a non-Carb state, does the Carb state warranty on the hybrid system still apply? Looking at a 2011.
  13. SteveLee
    645
    180
    North Carolina
    I
    Also I was told "The Hybrid battery is the original battery. There is no possible diagnostics to check the life of that battery." Am I wrong in thinking their equipment is capable of testing the health of the HV battery if they want to? It's a Toyota dealer.
  14. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    Gen3 if you don't do repairs yourself.
    SteveLee likes this.
