Gen 2 PCV replacement how-to with photos
Discussion in 'Knowledge Base Articles Discussion' started by galaxee, Dec 23, 2008.
  1. Omar Haddad
    Omar Haddad Junior Member
    31
    Sag Harbor, NY
    Hi all,
    Wouldn't it make sense to attempt to also remove the inverter coolant reservoir, just to get more room to maneuver around the PCV valve and get it out more easily? It would be good to even fit a torque wrench in there and give the new valve a specified tightness when you put it in. Why is nobody removing the inverter coolant reservoir for this process? Thanks.
