Gen 2 Prius all dash lights turned on while driving then car shut off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius gives me headaches, Jun 30, 2023.
  1. dolj
    dolj Senior Member
    8,440
    4,288
    Wellington, New Zealand
    Either send your cluster to Texas Hybrid Batteries to be repaired or buy a repaired unit then send your CM as a core. It is a $150 + $75 core charge which is refunded when you send in your CM. You also supply them your ODO reading and they program the CM with it for you.
  2. Prius gives me headaches
    Yes! Once I replaced the pump, it has never shut off on me again! I was thinking maybe it’s because the heat since it’s 106 here in Dallas Texas but I drove the Prius all around town and no issues! The car is a champ after that replacement
  3. Prius gives me headaches
    Are they a pretty good reliable source to send in my cluster? I’ve seen a bunch of services online and have been a little concerned on if I will get the cluster back or a they give me another non working cluster. Have you sent in your cluster with Texas hybrid batteries before?
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    I installed a combo meter from them a few years ago and it has been flawless.
  5. dolj
    dolj Senior Member
    8,440
    4,288
    Yes, they are reliable, unlike some online (read eBay, FB marketplace) sources, this business has a brick-and-mortar shop with a reputation to uphold. They also supply and install OEM hybrid vehicle batteries.
