Gen 2 Prius Exhaust pipe diameter?
Discussion in 'Gen 2 Prius Technical Discussion' started by GeneTherapist, Apr 20, 2019.
  1. GeneTherapist
    GeneTherapist Junior Member
    Drivers Seat
    Hi guys,
    I seem to have misplaced my measuring caliper. Does anyone know off the top of their heads what the exhaust pipe diameter on the Gen 2 prius is? Need to repair the pipe that connects the mid pipe to the tail pipe/muffler.
    Oh, and tin snips would be the safest way to trim the rusted portion of the pipe?
    Also, anyone know where I can buy just the complete piece of pipe between the resonator/midpipe and the muffler? That would be ideal. Muffler looks to have been designed to fail at the pipe rather than the muffler, so it's still in great condition.
    NortTexSalv04Prius likes this.
  2. Elektroingenieur
    2,515
    3,258
    Three Touring
    I don’t have the dimensions, but see parts catalog Figure 17-02, Exhaust Pipe, for the service parts available from Toyota dealers. The exhaust pipe is sold in two pieces, connected by bolted joints: the tail exhaust pipe assembly (17430-21580), which includes the muffler, and the front exhaust pipe assembly (17410-21500), which is very expensive because it includes the three-way catalytic converters. The gaskets are non-reusable.
    I wouldn’t try to cut an exhaust pipe, even if much of it is rusted away, using tin or aviation snips. There are special tools for this (e.g., Proto JFP770), or with the part removed from the car, you could use a tubing cutter, bandsaw, or hacksaw.
  3. Nozzavtr
    Nozzavtr Active Member
    155
    199
    United Kingdom
    I measured the circumference of the pipe on the diagram at the part labelled 17430, and it's 4.5 inches if that helps.
    SFO likes this.
  4. lunacyworks
    lunacyworks Member
    114
    SF Bay Area
    The pipe from the Catalytic converter is 1-7/8" ID and 2" OD from what I measured.
