Gen 2 Prius hatch back will not open
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Paul Polito, Dec 15, 2025.
  1. Paul Polito
    Paul Polito New Member
    Valley Center, CA.
    Hoping this is simple:
    When I try to open the hatch back on my 2009 Prius I hear an electronic noise like a lock disengaging, but the hatch will not open; stuck in the latch. This happened about a year ago and when I took it to Toyota (of course) it opened without a hitch. Is this a common problem? How can I get the latch to release?
  2. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    To open the hatch, just use the emergency latch. For the root cause, can be many things…
  3. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    If your combination meter is failing to light up intermittently, the hatch will not open.
    Combination Meter:
  4. Moving Right Along
    Moving Right Along Senior Member
    738
    594
    I found my hatchback would get stuck like that off and on when I hadn’t opened it in a while. I just had to keep trying and fiddling with it until it opened, and then after that I could close it and it would open okay.
  5. Hayslayer
    Hayslayer Active Member
    508
    306
    I've seen this previously in cars with failing combo meters. Hatch will not even try to unlock if the car power button had been pushed. Each time, the hatch could be opened by turning the car off and allowing the sks function to do its thing.
  6. pasadena_commut
    pasadena_commut Senior Member
    2,974
    915
    Southern California
    By "will not open" does the OP mean that after the release button is pressed the hatch does not pop up? If so, if the edge of the hatch is grabbed and upward force applied, will it open then? In addition to the combination meter issue it is possible that the rubber gasket has glued itself to the inside of the hatch. Using the inside mechanical release will distinguish between the two scenarios, since it will release even when the combination meter has issues.
    If the gasket is sticking, just clean it and the corresponding part of the hatch with a little bit of Dawn in some warm water on a damp sponge. (Not wet enough to drip.) Our hatch was sticking for a while, but since doing that cleaning, and one light treatment with Shin Etsu grease (from Honda), it always pops up when the button is pushed. The same treatment helps when car door gaskets stick. Thanks to ChapmanF for suggesting that grease.
  7. Paul Polito
    Valley Center, CA.
    so far, no signs of combination meter failure, no amount of force will open it and I could not find a manual release. Any other thoughts on this before I take it to Toyota?
    I know it is not a stuck gasket because it moves a wee bit but you can observe it starting to open followed by a mechanical sound of a closed lock. As you attempt to open it, it makes an electric sound and the interior lights go on. I believe that if it was a stuck gasket, I would have been able to tell.
    #7 Paul Polito, Dec 16, 2025
  8. dolj
    dolj Senior Member
    8,631
    4,385
    FYI, when you operate the hatch release button, it activates the release mechanism for about 0.5 secs. If you do not lift the hatch while the latch is released, it will catch the lock hook again, preventing the tailgate from opening. If this happens, you will need to operate the switch again and have another go at lifting the tailgate. The best place to grab the tailgate is at the bottom by the bumper cover with one hand while operating the release switch with the other.
    If you are having this problem, it is likely that the hatch struts are not providing enough lift to counter-balance the weight of the tailgate.
  9. pasadena_commut
    2,974
    915
    Southern California
    It is in a very unhelpful location. You need to remove the hatch "floor" and the big tray that sits under it to access it. This is a PITA to do form inside the car. Once those are out you will see a little plastic cover below and to the left (if I remember correctly) which must be pried off. The release is under that.
    dolj is probably on the right track with the timing and the latch. Grab the bottom edge with one hand then press the release button with the other, and immediately after it clicks lift with the edge hand.
  10. priumium
    priumium Member
    335
    Sweden
    2013 Prius Plug-in
    @Paul Polito Have you at all tried looking this up on YouTube? It’s such a common issue, there are hundreds of videos pinpointing this location. It’s a shiny metal piece. I also have a hard time finding it every time;
    So when you find it, add a strong string to the latch going upwards.
