Gen 2 Prius Strange repetitive noise from a/c - heater unit
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Theodore, Sep 2, 2025 at 1:22 PM.
  1. Theodore
    Theodore Junior Member
    39
    Greece - Athens
    Hi to all !
    I have the Prius Gen 2 , 2009 year and I am listening a strange repetitive noise, like "tak","tak" in in the middle of the dashboard and I believe, It's coming from the a/c-heater unit. Like a dumper which can not find it's position and goes on.
    I would like to point out, this noise goes on, even the clima unit is off.
    It stops only, when the car is off.
    What can I check first?
    I have experience to technical issues , as I am electronic engineer.
    51,393
    it does sound like a vent door that can't decide which position to stop at. i would start with a search. you might find that someone else has already done the legwork.
    if not, the service manual should cover it.
  3. Tombukt2
    Tombukt2 Senior Member
    12,567
    2,232
    Durham NC
    The two motors right by you're gas pedal foot attached to air box black square things put you're hand on to find the unit hunting . Remove look inside you'll see what to do it's indexed mark the wheel etc .
  4. ChapmanF
    17,642
  5. PriusCamper
    PriusCamper Senior Member
    12,241
    4,970
    Pacific Northwest, USA
    Are you certain its not coming from the engine compartment?
  6. Theodore
    39
    Greece - Athens
    Thank to all very much , for your replies. I understand what is the problem. The metalic potensiometer which give the position of the air mix dumper. It gives wrong position due to contacts dirty.
    I will open and clean all metallic contacts with pencil rubber eraser. It is the perfect tool for cleaning contacts like them, with out damage them
    #6 Theodore, Sep 3, 2025 at 9:12 AM
