Gen 2 Prius - Transmission Problem & Need Advice.
Discussion in 'Gen 2 Prius Main Forum' started by mttco, Jun 6, 2016.
  1. mttco
    mttco New Member
    I have a 2005 Gen 2 Prius with 135k miles in Glendale, CA.
    Problem: The engine started rattling like crazy and a mechanic I found on Yelp reported the error codes as Cylinder 1 misfire. He says they checked the spark plugs and they were good. He claims I need a re-built engine and quoted at $4000.
    The mechanic wasn't specifically a "Prius mechanic" - a friend recommended I post here and ask advise from you lovely Prius enthusiasts.
    Should I be trying to re-sell the Car if the repair is nearly worth the same as the engine? Is there anyone near Glendale, CA that could help me diagnose & verify this problem (I will compensate you) - I just need an opinion from someone that's a true Prius expert.
  2. JC91006
    16,673
    8,518
    Has your mechanic check to see if the coil was to blame? A used engine costs about $1500 installed
  3. mttco
    mttco New Member
    I honestly don't trust this guy. He claimed I needed a rebuilt engine before he even checked the codes. If there's any mechanics near Glendale, CA I will gladly have it towed to you and compensate you for your time.
  4. JC91006
    16,673
    8,518
    Has the car ever overheated?
    If not, then your most likely issue is the spark plugs or a bad coil. Why is your title "transmission" problem?
    #4 JC91006, Jun 6, 2016
  5. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    My recently acquired 07 ran like crap. Vibrating, hesitating, etc. P0301 0303 and 0304. $26 for new plugs. Running flawlessly.
  6. mttco
    mttco New Member
    No overheating at all until this incident... I guess my "Transmission problem" is a wrong statement. I guess I'm just a noob at knowing my car. But it's an engine problem and I think im getting swindled by a mechanic in Glendale.
  7. JC91006
    16,673
    8,518
    So my guess would be replacement spark plugs and possibly coil would fix your problem. Under $200
  8. mttco
    mttco New Member
    Thank you guys.
