Gen 2 ran for half a block leaking oil.
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, Apr 10, 2020.
Tags:
  1. Banksy
    Banksy Active Member
    415
    133
    Lancaster Pennsylvania
    So long story short is this
    And it's absolutely my fault.
    I changed the oil in my Prius for the first time and failed to notice the previous filters gasket stuck on the car. I ran the car around my block to circulate the oil and see if it needed some more.
    When I pulled in my driveway all I could see was a perfect line of oil doing around my driveway and around the block of my house.
    When I checked the oil pan there was maybe 1/4 or less qt of oil in there.
    Literally as I pulled in the triangle of DEATH came on.
    Now I added more oil removed said gasket and put on a new filter.
    However I am curious to know if some serious damage occurred.
    I haven't drove the car for a while due to waiting on and changing the HV battery
    I just drove it like ten miles and I don't hear any strange noises. However time will only tell.
    Just wanna get some input to see if any serious damage could have or probably did happen
    52,927
    i think you're fine. there is lubrication on the surfaces for a while
    Banksy likes this.
