Gen 2 shifts on it's own from drive into neutral!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SuzDP, Jan 23, 2022.
  1. PriusCamper
    PriusCamper Senior Member
    12,723
    5,143
    Pacific Northwest, USA
    That explains it. All those masks hanging from your shifter swaying around and bumped into over past near couple years is probably what did it. It's not designed for that... Just buy a used one online swap it out and problem solved. Probably only takes a 1/2 hour.
  2. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
  3. BuyJapanese
    BuyJapanese Member
    62
    31
    Wisconsin
    Oh Oh I know this one!! Maybe? This has been happening to me too, parking outside in Wisconsin winter. The shifter is just really sticky because it's so cold. So when I shift it into D or R the knob doesn't slide smoothly back to the default position, it gets stuck near the N position which then shifts the car to N. So after shifting to D or R I have to PUSH the knob back to the default position. It's not an issue once the cabin warms up. Possibly silicone lubricant on the shifter would help, I haven't tried.
  4. ChapmanF
    18,128
    The lubricant that's used in there is a white grease, quite possibly run-of-the-mill white lithium grease.
    The shifter is not hard to disassemble, clean the old peanut-buttery grease out of, and regrease with fresh stuff in the same spots. I would lean toward that approach over trying to indiscriminately spray some lube of a different kind into it.
    Another likes this.
  5. SuzDP
    SuzDP New Member
    Dana Point
    Three Touring
    I want to follow up on my original complaint of my 2008 Prius shifting on it's own into neutral.... Thank you especially to Chapman F and pasadena_commut! Since removing lightweight objects with metal from hanging from my shifter the problem has not reoccurred. I do believe the metal in proximity to the shifter interfered with the magnet signals functioning properly (excuse my layperson's explanation). Much gratitude! Nice for me to not be out the cost of replacing the shifter which wouldn't have resolved the problem anyway...
    Henrik Helmers, PriusCamper and bisco like this.
  6. Another
    1,819
    517
    Naples, Florida
    Which objects were hanging from the shifter?
  7. PriusCamper
    12,723
    5,143
    covid masks...
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,149
    Tampa, FL
    From the 2007 owners manual:
    Another likes this.
  9. Another
    1,819
    517
    Naples, Florida
    This is a much better option
    jerrymildred likes this.
  10. PriusCamper
    12,723
    5,143
    How dare you! You aren't supposed to read the owner's manual...
  11. jerrymildred
    11,517
    14,149
    Tampa, FL
    Reminds me of little Timmy who got called to the principles office for cheating. He asked how they knew he cheated. The principle said, "Because you sat next to Jimmy and all of your answers were the same as his except on number seven, he said, 'I don't know,' and you said, 'Me neither.'"
  12. Pioneerscot
    Pioneerscot Junior Member
    78
    Nevada
    I’ll be delving into this annoyance on my 08, it has never had anything hanging on th shifter, but both times it has happened have been after the weather has warmed up. Also I had just used the “ B “ we live in very hilly area of north Reno. Anyway, it was even going to neutral from reverse. The thing that helped was turning the car off, then back on a min later.
    Anyone have a source for the shifter assy ?
  13. PriusCamper
    12,723
    5,143
    Keep in mind that when the hybrid system failure gets severe enough the car will be stuck in neutral... That will come with warning lights and error codes too.
    Pioneerscot likes this.
  14. Pioneerscot
    78
    Nevada
    Yeah, I’m wanting to replace that part before that happens, just need to find one
  15. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    They're all over ebay for about $30. Just do a search for 2008 Prius gear shift
  16. Pioneerscot
    78
    Nevada
    Yes, thank you, I found and ordered one.
  17. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    462
    Leawood, KS
    I
    I had this happen to me. Culprit was a collection of black hair bands my wife was storing on the handle....I took them off...problem solved.
