For Sale Gen 2 smart key
Discussion in 'Private Sales' started by RichardB, May 22, 2020.
  1. RichardB
    RichardB Junior Member
    Adirondack Park
    I have a working used Gen2 smart key from a 2004 Prius, the key was purchased in 2012. $20 with free shipping so it can find a new home.
  2. Prius717
    Prius717 Junior Member
    51
    Lancaster County PA
    Can it be programmed to another prius?
  3. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    Not without special equipment
    iPhone ?
  4. Dale2005
    Dale2005 Junior Member
    25
    25
    San Diego
    In my experience a used Gen2 Smart Key can be programed using Toyota Tech Steam to a new car however it will not operate as a Smart Key. The remote lock functions will not work and the proximity sensor to use the touch locks will not work. It at best will be a dumb key that can used to start the car if placed in the key slot. You can assume the little metal key has been cut to fit the original car. Blanks are available on ebay or your take your original metal key and have a standard size key cut as a spare at any place that cuts house/car keys.
    This gives you a solution for a lost smart key when away from home. Imagine this: you can have a metal key hidden on the outside of your car so you can unlock your car and you can hide the dumb key somewhere on the inside of the car to start the car once you get inside.
    Only Smart Keys that have been used fewer than X times can be reprogrammed for a different car. I think X = 50 but I could be wrong about this number. If this Smart Key has been used more than X times it at best can become a dumb key used to start the car if reprogrammed with Tech Stream.
  5. Banksy
    Banksy Active Member
    415
    133
    Lancaster Pennsylvania
    I'll take it
