Gen 2 vs gen 3
Discussion in 'Gen 2 Prius Main Forum' started by Archer Berzins, Apr 29, 2021.
  1. Archer Berzins
    Archer Berzins New Member
    Floyd Virginia
    Hello all!
    I’ve decided I’d like to buy a used Prius, and there seem to be two prominent options in my area. I can either go with a 2013 with around 155000 miles for 7000, or a 2008-9 with around 140000 miles for about 5000. Any opinions on the better buy?
    Thanks!
  2. Archer Berzins
    Floyd Virginia
    I should add, there’s a particular 2013 I’m looking at with 155000 for 7000 with an immaculate service record, oil changed often, recently replaced tires, etc.
  3. PriusCamper
    PriusCamper Senior Member
    13,467
    5,436
    Pacific Northwest, USA
    I like the Gen2 because they're more simple in terms of doing repair work. But either way, both of your options sound great.
    52,863
    sounds like a repair nightmare $$$$$$$$$$
  5. bisco
    52,863
  6. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Would stick with the gen2, and apply the savings on a new battery when the time comes. You may want a new HV lithium pack.
    PriusCamper likes this.
  7. frodoz737
    frodoz737 Top Wrench
    4,807
    2,561
    33
    I would suggest that "if" you are cost restricted...stick with a low mileage Corolla or Civic. Knowing nothing but what you provided about the 2 vehicles...there are some major costs coming soon for both.
  8. Moving Right Along
    Moving Right Along Senior Member
    739
    596
    According to data from Toyota Prius Reliability - Dashboard Light, a 2009 Prius is typically a bit more reliable than a 2013 Prius. The clean record and service history on the 2013 is good, but if you can find the same for a 2009, I’d go with that instead.
  9. The Lizard King
    89
    56
    I would by a 1970 Chevelle SS 454 LS6 instead. Good luck.
