Gen 3 170k miles oil viscosity
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MeGuinness, Jun 29, 2016.
  1. MeGuinness
    MeGuinness Member
    217
    78
    UK
    So should I keep using 0/20 oil with this high milage or change to a different viscosity? What is best guys ? I'm in UK.
    Thanx
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
  3. tankyuong
    1,555
    662
    Central MO
    I switched to 5w20
  4. Indy John
    Indy John Member
    75
    33
    Indianapolis
    There is zero logic to switching from 0W anything to 5W anything. Experts agree that most engine wear occurs during the first minutes after cold start-up (e.g. 75 degrees F). There is currently no engine oil thin enough to lubricate properly at cold start-up, and 0W is currently the thinnest available. "W" indicates a different cold-weather test standard than regular testing, which is done at 212 degrees F, considered to be normal operating temperature. Mobil 1 0W-20 and 5W-20 have the same viscosity (measured in Centistokes - cS) at 212 degrees F, which if I remember correctly is 8.7.
  5. Mendel Leisk
    42,271
    Is the oil level dropping between changes? If so how much? And how frequent are your changes?
  6. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    ... and what's the mileage on it now?
  7. MeGuinness
    MeGuinness Member
    217
    78
    UK
    10k interval and yes the level goes down of about 60% in between, 170k miles!!
    CR94 and Mendel Leisk like this.
  8. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    So, if I understand correctly, it's consuming about 0.9 liter (1.6×60%) per 10,000 miles (or 10,000km?) ? That rate isn't so bad, if it's stable. Before the Prius, I never had a car that consumed that little.
  9. Mendel Leisk
    42,271
    @CR94 I took "60%" to mean 60% of the spec quantity of oil: 4.2 liters or 4.5 quarts, about 2.5 liters loss.
    By "1.6" I'd assuming you're meaning the quarts between the two dipstick marks, another likely interpretation, and likely the correct one.
    @MeGuinness : Can you give a specific oil loss?
  10. CR94
    CR94 Senior Member
    2,819
    1,238
    Northwestern S.C.
    I agree that that was unclear. Either guess, or neither, could be right.
