Gen 3 2013
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wendi, Jun 27, 2019.
  1. wendi
    wendi New Member
    Temple,TX
    Error code cylinder 2 misfire so replaced spark plugs and coil pack, now engine shakes like a motor mount is broken but have checked all and they r fine. Any one having this problem or can help with ideas on what to do next? Thanks in advance
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Clean your get circuit
  3. tankyuong
    1,555
    662
    Central MO
    Egr circuit
  4. Mendel Leisk
    42,355
    How many miles on it?
    Is the engine coolant level dropping in the reservoir?
    It may well be leaking head gasket; a leak-down test would be good to check this.
    EGR circuit cleaning is always good, if you've got over 100K miles it for sure needs doing, but at this point may be "closing the barn door after the horses have bolted".
    Also intake manifold should be thoroughly cleaned, and if you want to help keep the EGR and intake manifold cleaner down-the-road: look into oil catch cans.
    #4 Mendel Leisk, Jun 27, 2019
  5. wendi
    wendi New Member
    Temple,TX
    150,000 miles and not that I have noticed I dont drive it due to the problem
  6. bisco
    52,863
    welcome!
    are you going to diy?
  7. Mendel Leisk
    42,355
    Just occurred to me: this thread would be more at home in Maintenance and Repair forum, I'll flag the mod's.
  8. wendi
    wendi New Member
    Temple,TX
    Yes I am because I live on a disabled military vet income so....
  9. bisco
    52,863
    are you using tech stream?
    definitely clean the egr as mentioned above. have you done the throttle body and maf?
