Gen 3 Bad inverter P0A94
Discussion in 'Gen 3 Prius Main Forum' started by AJ200, Mar 11, 2017.
  1. AJ200
    AJ200 New Member
    28
    NZ
    Toyota say we need to change the inverter.
    I read somewhere that if the dashboard says ready the inverter is not bad the water pump is.
    Also the inverter coolant is not moving at all, could it be just a bad pump? Or Will the pump not work unless the inverter is working? Also will any Gen 3 inverter fit the 2010 or does each year have its own?
    52,880
    were you part of the recall?
  3. AJ200
    AJ200 New Member
    28
    NZ
    I don't know, got the car second hand. We assumed Toyota would tell us if it was part of the recall when we took it in for a scan.
    52,880
    sometimes they do. it might be worth plugging the vin into the owners website. it will show open recalls, as well as any service done.
  5. Zamprius
    Zamprius Junior Member
    Fiji
    2012 Prius Alpha
    Hi
    Did you manage to fix the above issue.. my prius alpha 2012 has the same codes and it displays Ready but only allows to drive to a certain speed.
    Thanks
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Id pay to see that.
  7. ChapmanF
    19,046
    Everybody wants a way to read tea leaves. The car will be happy to give you trouble codes saying what's what.
