Gen 3 Brake Pedal Springy sound on press
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by munchkinpot, Oct 21, 2016.
  1. munchkinpot
    munchkinpot Junior Member
    Camarillo, California
    Hello, been experiencing this metal "springy" sound on my brake pedal when I press on the brakes a little on the hard side.
    Just recently, when I shut the car off and stay in the car for a good minute or two, even not pressing on the brakes, it makes like was vacuum pressure was released together with the metal springy sound.
    Brake accumulator recall is done 10k miles ago, front brake pads done 5k miles ago.
    what could this be?
    52,891
    sounds normal to me.:)
  3. ChapmanF
    19,053
    The car does normally go through a little brake self test a couple minutes after shutting down ... makes some clicks and squirty noises.
    Without a recording, I'm not sure what you're calling a "springy" noise, but if the accumulator recall's been done, it's not likely the accumulator....
    -Chap
    munchkinpot likes this.
  4. munchkinpot
    thank you, the car is at 111k miles right now and accumulator recall has been done @65-70k miles.
  5. bisco
    52,891
    when i press my brake pedal, it sometimes sounds like a spring being stretched.
  6. munchkinpot
    same here!!
  7. bisco
    52,891
    i should have said 'sometimes'. i'm not sure what causes it, but keep in mind the brake pedal is electronic, not physical.
