Gen 3 Certified Preowned 33,000 Miles - New Brake Pads?
Discussion in 'Gen 3 Prius Main Forum' started by MartinGale, Jul 21, 2017.
  1. Tande
    Tande Active Member
    539
    322
    Mich.
    IMHO.....you would have to beat on a Prius pretty hard to need front brake/pads in 33,000 miles.....(n)
    CNYhybrid likes this.
  2. Mendel Leisk
    41,486
    Yeah but dealership still might have changed, regardless of "need".
    I've already changed rears on ours, due to my earlier screw up.
  3. Tande
    Tande Active Member
    539
    322
    Mich.
    True......
  4. harrysprius
    harrysprius Active Member
    277
    126
    Nashville, TN
    The braked pads part doesn't bother me. There are enough dealers out there taking advantage of people that I wouldn't be surprised at all. That being said I'm sure there are plenty of honest ones to, I just haven't found any yet!
    If you have the entire VIN umber you can type it in on the Toyota web site and see every service done at Toyota.
    Good luck!
  5. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    Seems early, my car is at 137k miles and still has about 3mm left. The manual says to replace pads with 1MM left which is kind of nuts.
  6. Mendel Leisk
    41,486
    Not quite. The language is something like "mininum thickness: 1 mm". But common sense should prevail, if you've opened up the brakes and you have only 2~3 mm remaining, I would change them.
    I think wear accelerates as the pads thin, and too: the thinner they are, the less mass they have to dissipate heat, and the they may start to lose fragments off the edges.
    Maybe think of them like tires: you're not obligated to run them down to the wear bars.
    harrysprius and bisco like this.
  7. AliPK
    AliPK Member
    71
    30
    Pakistan
    Go for second opinion from dolifdernt
    Go for 2nd opinion from another mechanic.that doesn't seem right
  8. Jkan2001
    Jkan2001 Member
    201
    62
    Dallas TX
    I agree thinner pads dissipate heat worse but I can't think of any normal driving situation where you would get your pads hot enough to boil the fluid and get brake fade in a Prius. I toss my track pads in my BMW's and Porsche's when the pad thickness reaches the backing plate (5mm) but I never drive the Prius aggressively at all.
  9. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
    I bought my car at 40k, now it's at 60k, 2013 vehicle.
    Dealership says I've got 3mm on the fronts.
    Should I replace ?
  10. Mendel Leisk
    41,486
    Myself, I would at the next service interval, next time the wheels come off. Not a panic, but neither would I hang about.
  11. MartinGale
    MartinGale Junior Member
    23
    I am sorry for the delay on providing the conclusion of my car purchase. The salesperson for the dealership with the 2014 with the CarFax revealing the disabling accident had not gotten all the agreed conditions of purchase approved. When it came to do the deal, she started adding on additoinal charges. I managed to get my sick 2007 to limp the additional 20 miles to the dealership with the car with the clean CarFax.
    I had made them an out the door offer for $12563.00 including my 2007 Prius with the bad hybrid battery. The car was to be inspected and any work needed to be Certified Preowned was to be included with 2 key fobs.
    Breakdown on the price:
    Cash Price of Vehicle $14971.00
    Trade in for 2007 Prius ($3500.00)
    Sales Tax $716.94
    Dealers Inventory Tax $33.31
    Documentary Fee $150.00
    Registration Fee $110.50
    Title Fee $33.00
    County Road & Bridge Fee $20.00
    Inspection Fee $23.75
    Processing & Handling $4.75
    Balance Due 12563.25
    I would have to spend $2376.00 on my 2007 to replace the hybrid battery. So effectively I upgraded from my 2007 with 138,000 miles and a dead hybrid battery which would cost $2376.00 for a net cost of $10,187.25.
    For certification the dealer installed 4 new all weather tires at no charge to me. I got my 2 key fobs so, everything went pretty well.
    I will also comment on the differences besides the obvious of a 2007 versus a 2014. This 2014 vehicle is a white exterior. My 2007 was black. Observation is “WOW.” When parked in the sun, the newer white car is considerably cooler, or more correctly stated not as hot as the 2007 with black exterior. We generally run the AC on 74 and are comfortable. I do not know if the headliner and window glass have increased insulation from the heat, but it is a remarkable difference.
    I still have not officially gotten 50MPG out of the 2014 but I have no doubt I will get there. Most of my trips are 10 miles or less with the exception of occasional weekend trips. We wind up with a lot of idling time as my wife prefers to not get out of the car when I go to the store. Currently the estimated MPG is 54.2 so I am in hopes of finally getting my 50MPG on next tank of gasoline. Keep in mind I am in North Texas and even with the outside temperatures are not roasting hot, the sun is frequently intense.
    Overall very happy with the purchase. I am in the process of putting together an Android head unit with CD/DVD player, GPS, backup camera, dash camera, Bluetooth and a few extra video inputs. I am also installing an external HDRadio tuner. Hopefully I can get rid of my Garmin so it is not always in the way.
    Thanks for all those who offered their advice.
    harrysprius, jerrymildred and RMB like this.
  12. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    We sold our 2008 Gen II with 173K miles. The brakes had never been replaced and I was told they were in good condition.
    Some people drive with two feet on the pedals. One on the gas pedal and the other on the brake pedal. Someone taught them that way and they can go through brakes very quickly. My dad used to have an automotive repair business and saw this problem all too often.
  13. harrysprius
    277
    126
    Nashville, TN
    Great info Mendel. My experience is the same. The first 25% of the pad thickness seems to correlate to the first half of the brake life. The last 25% of the pad seems to go way faster. Maybe like 10% of the brake life. That's not scientific, but overall that's the way it's been in my experience; and I bet I've put on enough brake pads to fill the average persons garage.
  14. harrysprius
    277
    126
    Nashville, TN
    Congrats Martingale! It sounds like your happy and that is what it's really about. The older I get the more I come to realize that.
    I had to find a car in a rush last summer due to an idiot driver texting and hitting me from behind. Totaled my car in the middle of relocating for work and buying a new house. I ended up taking a black car as a replacement because the price was right and it fit the bill and budget. I noticed the heat difference immediately. Luckily I was able to wrap up the move and house and start looking around. That's when I found the prius, in white. Now my daughter has to deal with the other car. It's amazing how 16 year olds don't care about that stuff. They just want to drive!
  15. MartinGale
    23
    When I helped my daughter buy her first car (used), if the radio sounded good - she wanted it. Oh, to be young an not so smart.
    Sometimes I do long for those days, then I remember how it was to be young. I am beginning to think old is a good thing.
    Raytheeagle likes this.
  16. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    You guys described me in my youth. Black paint with a nice sound system and I was in!
    These days, I still like a nice stereo- much nicer than what the Prius provides. But a black car under the Vegas sun is too much for me to handle these days.
  17. harrysprius
    277
    126
    Nashville, TN
    Mine's got the JBL system, and it sounds really good to me. I'm not sure why everyone thinks it sounds so bad. My daughter loves it.
  18. MelonPrius
    839
    516
    Nevada
    I cannot comment as I don't have the JBL. But my assumption was that the upgraded system would have sounded excellent- which is not what others have posted, though.
    I can attest that the standard speakers leave a lot to be desired, and I'm not as picky as most. I have some preowned CDT speakers being shipped, I can't wait.
