Gen 3 Dead accessory battery, manual key won't unlock door
Discussion in 'Gen 3 Prius Main Forum' started by cagemo, May 4, 2019.
  1. ASRDogman
    ASRDogman Senior Member
    7,596
    3,916
    CO2 is GREAT for plants and tree, which produce or change or however you want to say it or put it
    in AIR.....
    C Wagner and Grit like this.
  2. Mendel Leisk
    41,463
    C Wagner likes this.
  3. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    Awhile back my wife couldn't get into her car even with the manual key. Turned out she had the key for MY car, but her key fob in the house was close enough for her to start the car and drive to the store.
    Moral of the story .... is the OP using the right key?
    C Wagner and Mendel Leisk like this.
  4. Mendel Leisk
    41,463
    In a more traditional key, the key’s electronics are bonded with the key, no risk of mix up. They’re still expensive but at least there’s that.
  5. ASRDogman
    7,596
    3,916
    Doesn't the fob have to be within 6 feet or so to activate the car?
    And the car can tell if it's inside the car? I know if I stop out of my car it starts beeping
    and having a hissy fit that the key fob can't be found.
  6. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Daily battery driver, connected to solar roof panel and sub woofer amplifier. Quick disconnects onto jumper cables, don't be found on road dead.
  7. GuamKelly
    GuamKelly Member
    274
    68
    Ipan, Guam
    It was in a kitchen drawer, at least 30 feet from the car, but the car did start and she drove all the way to town.
    But if it's in my pocket under my phone it can't be found. Go figure.
  8. C Wagner
    C Wagner Member
    183
    60
    Boston
    I just tested my Prius again with battery disconnected and car doors all shut and locked - think about how tricky that was to do - and, after applying lock graphite liquid, the mechanical key works wonderfully now! Yay.
    By the way, these fobs are a pain- I’m always setting the panic alarm off. No more! I dug the orange cap out and super-glued a plastic panel over the orange button area! No awkward false panic anymore!
  9. YuriR
    YuriR Junior Member
    22
    I have a similar problem with gen3, but my battery is disconnected and car is locked. I tried mechanical key and it doesn't open the driver's door. I am not sure if there is a mechanical lock when turning the key, the key was hard to turn at first, now it is turning both directions about 45 degrees but nothing happens. Feels like the key is not right, is it possible to turn the key if it is not correct?
  10. C Wagner
    C Wagner Member
    183
    60
    Boston
    I think I had a similar situation. Did you try graphite liquid or even repeatedly rubbing pencil on your key and repeatedly inserting it?
  11. bisco
    51,944
    probably disconnected inside.
