Gen 3 Engine Swap + HV Pack Charging Alternative
Discussion in 'Gen 3 Prius Technical Discussion' started by Oldmanriver, Mar 13, 2021.
  1. Oldmanriver
    Oldmanriver Junior Member
    28
    Pittsburgh, PA
    Hello so I picked up a Gen 3 that is in the same condition that my Gen 2 was in (rod through the block) I did the Gen 2 swap a few years ago and it is still relatively fresh in my mind, but wanted to see what I need to consider with my approach between the two. I see some people using a Gen 4 engine for the 3's my goal is to install a good working engine all while being efficient with my time and money.
    What if anything can I do to charge the HV pack while the engine in inoperative... Trickle charge at the terminals...?
    Also I am considering buying a Gen 2 parts car (Red) for a few body panels. If anyone is in need of parts I'd be willing to test, disassemble, and ship.
    Thanks in advance!
    Raytheeagle likes this.
    52,807
    cheap: you can charge individual modules with a hobby charger
    expensive: you can charge the entire pack at one time with a grid charger
  3. Oldmanriver
    28
    Pittsburgh, PA
    Thanks Bisco! I didn't want to crack the pack open nor do I want to make an expensive purchase for something that will not be used often enough to justify a purchase. The previous owner stated the car has only been sitting a coupe weeks, but I don't believe that to be true!
    155K on the vehicle HV indicator is at 1 bar I wanted to charge the pack while I pull the bad engine and source a replacement
  4. Dusty0123
    Dusty0123 New Member
    Powell, WY
  5. Dusty0123
    Powell, WY
    I would like to know this as well. I am down to 187v
  6. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    It is possible to assemble a charging kit from inexpensive equipment.
    Build Hybrid Battery Maintenance Gear For Under $100 | PriusChat
    Brian1954 likes this.
