Gen 3 Engine Valve Stem Seal Replacement
Discussion in 'Gen 3 Prius Main Forum' started by Chris Hammond, Jun 9, 2022.
  1. Chris Hammond
    Chris Hammond New Member
    Bloomington, Indiana
    I am in the process of replacing my 2010 head gasket and got a full gasket set from Amazon (Evergreen brand). The new stem seals are blue and orange, but there is no documentation as to which one goes where. Anyone have experience with which color goes on intake and exhaust?
    Thanks,
    Chris
    PriusCamper likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,476
    5,441
    Pacific Northwest, USA
    Looking forward to knowing the answer to this... In the meantime what were your options for headgasket kits and reasoning for going with the one you did? I'm procrastinating on buying a kit for a 2013 and need to research it more!
  3. Mendel Leisk
    42,379
    Part no for the Toyota gasket kit (and head bolts) in the attached, fwiw.
  4. Chris Hammond
    I broke down and paid $285 for the Toyota gasket kit at my local dealer. I should have done that in the first place, so I have my self to blame for trying to save a couple of bucks. The seals are different materials and I did determine that the intakes have a small groove on the inside of the smaller diameter and the exhaust do not. I am returning the Evergreen kit to Amazon and have another Toyota head gasket that I will sell too (since my new kit came with everything anyway.
    Chris
    mikey_t and ASRDogman like this.
  5. PriusCamper
    13,476
    5,441
    While I'm fairly certain that there are way cheaper head gasket kits than OEM that are actually higher quality... You are approaching this situation intelligently by thoroughly inspecting the quality of the kit and not letting price define quality, but letting your own eyes and experience with materials design define it. That's smart! Wish people would do that more often!
    Foxglove and mikey_t like this.
  6. ttou68
    ttou68 Active Member
    351
    211
    FYI, it maybe too late to reply but for future reference...
    Toyota dealerships usually have an online store you can order and pickup, price are very from dealership to dealership but usually cheaper then retail. In my case the kit currently listed is $160.14 online, and and 148.14 from another dealership online part store...
    I like the OEM kit, but as head gasket itself I do feel Felpro head gasket is better than OEM head gasket...
  7. Lemon Drizzle
    Lemon Drizzle Junior Member
    Hall Green, West Midlands
    Also does anyone have a step-by-step instruction on how to replace stem seals...? A video would be even better but I realise I maybe asking for a bit too much.
  8. ToyXW
    ToyXW Active Member
    153
    149
    Sacramento
    Ideally you pull the head off and use a spring compressor to remove the retainers and access the valve stem seals, but it is possible to leave the head on. Here's an example on a corolla:
    Again I prefer to pull the head and do a full inspection, head gasket replacement, & valve job, but if you just want to get by with the minimum effort it is possible to leave the head on...
    #8 ToyXW, Jul 5, 2022
    Mendel Leisk and PriusCamper like this.
  9. Lemon Drizzle
    Thank you, thank you.
