Gen 3 facelift.
Discussion in 'Gen 3 Prius Main Forum' started by Padraig, Nov 10, 2019.
  1. Padraig
    Padraig New Member
    Ireland
    Hi. I know the gen 3 Prius came out around 2009. I know some early gen 3’s had inverter issues.
    Did the gen 3 get a facelift?
    If so when...and is it possible to identify? (Different interior etc)
    Did the facelift fix the inverter issue? (I think I’ve heard mentioned it may have been sorted in 2014)
    52,670
    a facelift is not the same as updated mechanicals. they did the body face lift in the 2012 u.s. model year.
    mechanical/electric issues were hit or miss. i don't recall inverter issues. there was a recall for the diodes inside to prevent burnout from high electrical draw, which could cause the car to stall at high speed
    a bigger concern is egr clogging and oil burning
    they updated the rings in 14 and pistons in 15
  3. Padraig
    Padraig New Member
    Ireland
    Thanks. Any way to tell the ‘body’ facelift in 2012.
    So one would nearly want to get a 2015 Prius to be sure of it not running in to issues?
    #3 Padraig, Nov 10, 2019
    52,670
    15 would be your best bet, but more costly, naturally.
    one obvious facelift is two exposed cupholders in the console, vs one before the facelift
  5. BZzap!
    BZzap! Senior Member
    1,607
    878
    The 2012 Face lift (front Bumper cover) consisted of a tapered or sculptured Day time running light change.
  6. Padraig
    Padraig New Member
    Ireland
    hi
    but would you know this from just looking at the car in an ad. Just looking for obvious ways to tell.
    2 x cup holders is one way, any others ?
    #6 Padraig, Nov 11, 2019
  7. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
    Taillights changed in 2012
  8. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    That is the most obvious. They went from a red section at the top to ski shapes along the outside edge.
  9. Mendel Leisk
    42,165
    Pistons in 14, rings in 15.
    Think what would be logical, then it's the inverse.
  10. bisco
    52,670
    Thanks, I’ll never remember (n)
  11. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Cosmetic updates doesn't fix any electrical existing issues. If it did fix the inverter over-heating issue, I'd slap on a 2014 front bumper on mine.
    #11 Grit, Nov 11, 2019
  12. Mendel Leisk
    42,165
    That's like me and @ChapmanF : there's a couple of brake components on the firewall, I can never remember the name of either; he always comes along to sort it out.
  13. Mendel Leisk
    42,165
    IIRC, there's something inside the inverter housing, which Toyota says is not considered part of the inverter, for warranty purposes. You can't make this stuff up, lol.
    (I sometimes wonder if I'm sailing a little close to the wind, considering Toyota maybe has some sponsorship status on this site. But how can it be slander, just stating info that's their public record? :whistle:)
    Here we go:
    IPM Extended Warranty (Canada?) | PriusChat
  14. elementnomore
    136
    44
    Los Angeles
    So my inverter blew up or died, don't ask me the engine code... All I know is that one morning the car wouldn't start in the garage. I had it towed to my local dealer...And because 'I had done all the software updates' on my 2012 (I think 2 of them) they replaced the inverter the dealer said. This happened about a year ago and I am under 100K if that all helps you some.
    AltraStache, bisco and Mendel Leisk like this.
  15. Mendel Leisk
    42,165
    Cautionary tale for refuseniks?
    elementnomore likes this.
  16. elementnomore
    136
    44
    Los Angeles
    I am not sure if the dealer was trying to pull something on me, they didn't say THEY pushed for it but the car was fixed... I like my 2012 but am getting itchy for all the safety features of the newer Gen4 so mine might go up for sale. Car has been completely reliealable up until that issue. 98K, same brake pads...
    AltraStache likes this.
  17. Prodigyplace
    12,706
    11,847
    Central Virginia
    I know there were mechanical updates to the 2015 Prius v to improve the front offset crash test results. My son has a 2015 Prius v.
  18. Mendel Leisk
    42,165
    For the fourth gen's, I'm mostly just bilious...
    I like a lot of the under-the-skin stuff, but the dash, interior in general, not so much. Exterior, it looks like something that escaped from Disneyland.
    AltraStache and Attila Fekete like this.
