Gen 3 Headlights.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by raymonty, Oct 9, 2024.
  1. raymonty
    raymonty Junior Member
    Dahlonea, GA
    What are the best headlight lenses for a Gen 3, pray tell.
  2. Tombukt2
    Tombukt2 Senior Member
    13,798
    2,501
    Durham NC
    Aux beam top line S series. No fans. When you install a bulb like this in this type of plastic fake type projector you'll need to crank the adjusters down in about eight turns towards the ground you'll magically see your cutoff appear set that cut off line on your garage door at the proper height I don't know the inches right off and then that's it and I'll do the other side very good bang for the buck.
