Gen 3 Inverter Failure
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AubreyIII, Aug 17, 2017.
  1. AubreyIII
    AubreyIII Junior Member
    Montgomery, AL
    Welp, I got the dreaded "Check Hybrid System" yesterday. Had it towed to dealer for diagnostic, they reported the following codes:
    P0A78-282 DRIVE MOTOR "A" INVERTER PERFORMANCE
    P3004-132 HIGH VOLTAGE POWER RESOURCE
    Their conclusion was a bad inverter. I couldn't afford a new one, as I JUST REPLACED THE ENGINE LAST WEEK, so I had it towed home. I've ordered an inverter from LKQ with 55k miles for $360, and will replace it myself. It will arrive tomorrow but I probably won't be able to do the work until next weekend.
    FYI the car has 148k miles on it.
  2. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    Salvage title?
    If the car is clear title, it's warrantied for 15 years/unlimited miles.
    Raytheeagle and Lightning Racer like this.
  3. JC91006
    16,933
    8,643
    Strange coincidence. What led up to the engine replacement?
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    better get the techstream to clear codes afterwards
  5. AubreyIII
    Montgomery, AL
    Dealer and Customer Care both told me it's 10 years, 100k on the inverter. I think the 15 year coverage is only in CA.
  6. AubreyIII
    Montgomery, AL
    Blown head gasket.
  7. AubreyIII
    Montgomery, AL
    Really? What's the issue? I planned to take it to dealer after I replace the inverter to make sure the inverter software is up to date.
  8. bisco
    52,784
    they have tech stream, and can clear them.
  9. m.wynn
    684
    1,230
    Queensbury, NY
    Print the ZE3 letter, take it to the dealer (or maybe to a different dealer) and see if it helps them understand. If they still don't "get it", take it to corporate. Crazy to buy a who-knows-what condition used inverter and pay a questionable dealer to install when you've got it coming for free. Again, assuming clear title.
  10. Mendel Leisk
    42,271
    ^ And this guy's in New York.
  11. AubreyIII
    Montgomery, AL
    Thank you! I did just that, Waiting to get a ruling from Customer Care.
    Raytheeagle likes this.
  12. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    General question for anyone: Were they just confused between the inverter and traction battery warranty? Or are there different extended warranties on the inverter for different Gen III vehicles? I have the 15 year, unlimited miles extension- but I moved the vehicle from a CARB to nonCARB state. I assumed that doesn't make a difference, but now I want to doublecheck.
  13. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Warranty Enhancement Notification ZE3 is VIN dependent. Register the VIN at http://www.toyota.com/owners to see if the car is covered. Cars delivered with the "improved" inverter are not covered.
  14. John0163
    John0163 New Member
    Houston
    My 2013 experienced the total shutdown of the hybrid system last week and quite a few of the dashboard warning lights were all lit. Took to local mechanic and he said I had the two engine codes P0A7A and P0A9A and he referred me to the dealer. Dealer says my some computer parts in the inverter had failed (yes he was not very specific) and they would be fully covered under factory warranty. He stated that there are very specific error codes and conditions that would qualify it for warranty repair and that it the dealer would honor the warranty for 20 years. Dealer was very professional and even provided me a brand new loaner car for a week while they performed the repair work.
    ASRDogman likes this.
  15. ChapmanF
    18,959
  16. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    How do we know if the inverter we have is the improved one? any specific serial number or sticker?
  17. ChapmanF
    18,959
    I don't know that the hardware is any different. It should have the bug-fixed control logic flashed into its MG ECU, and your car's power management control ECU should also have an update flashed. You can tell if these things have happened by looking at the calibration IDs shown in Techstream.
    johnHRP likes this.
