Gen 3 Motor Issues - Piston Soak - Blowby Pressure
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Paladain55, Nov 14, 2022.
  1. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    So as most of us know the main issue with the 2010 prius is the piston rings which causes a lot of secondary issues. Whether that issue is solely from "low friction piston rings" or a combination of that and 10k oil changes we will never know. The damage to most cars is probably already done. I think its safe to say now that most of us agree to do a 5000 mile synthetic oil intervals at max to prevent further clogging/damage. I have also swapped to Pennzoil Ultra Platinum Full Synthetic although i doubt it will make a measurable difference in oil evaporation which goes into the intake to be burned through the PCV valve but hey every bit helps.
    So the way the PCV system works is you have two pcv ports. The port on the valve cover is the breather port and the secondary port at the bottom is the exhaust port which is connected behind the throttle body on the intake manifold with a check valve inbetween. So at throttle conditions less than wide open the intake manifold will have a vacuum to a varying degree where idle should have the strongest vacuum being pulled as the throttle valve should be closed the most. The pcv valve controls the flow through the bottom port so at cruise with the throttle valve somewhat closed it pulls a vaccum and the valve allows it to pull that vaccum on the crankcase. This vacuum giving a small benefit in mpg from the pressure reduction and the secondary benefit is it sucks out the blow by vapors that enter the crankcase through the piston rings on compression stroke and effectively keeps the oil a bit cleaner and if the pressure differential is off the upper port allows air to flow in or out. Its a tuned flow as the pcv valve only allows so much flow into the intake manifold and the upper breather port has been reduced in size internally to tune flow further. The blow by gases are comprised of water, unburnt gasoline, and burnt exhaust. So this is why you get a lot of brown goo in your catch cans as its not just oil its a lot of blow by filled with other liquids as well. Also the pcv valve is a check valve so it only allows one way flow etc... At wide open throttle there is no intake vacuum and the crankcase pressure from the high amount of RPM from the pistons and blow by then close off the lower pcv port and that excess pressure goes out the top breather port into the intake before the throttle body. I'm sure many prius mostly see the former condition and not much racing. But also these are atkinson cycle engines with EGR valves and they like to keep the throttle valve mostly open to reduce pumping losses so I wonder if that effects the vacuum the car pulls on the crankcase versus a normal engine without all of that.
    Anyways, I just wanted to type that to catch people up. I see a lot of threads and it is clearly some people don't understand how the pcv valve works.
    NOW to my thread:
    My 2010 was having egr issues like 15,000 miles ago. I saw the gasket masters video where they unplug the electrical connector on the car to diagnose if the egr system on your car is clogged. If it is clogged the car will instantly start to run better with it unplugged. I ran the car like that with p0403 temporarily until i cleaned the egr system, and the i decided to just leave it unplugged. If I ever need to go cel free i can plug it back in. But i somewhat dread having to do that cleaning process multiple times more. After I got the egr pinging issue fixed I tried to figure out the oil consumption issue. This car would consume probably half a quart in 400 miles on the interstate if i let the car use cruise control through the mountains, but if I didn't use the cruise and kept the RPMs below 3000 RPM the oil consumption stays around a quart every 6500 miles. So this points me to piston rings. I then verified it as well as when you take off the oil cap you get a nice flow of air which is well above normal so the car has a lot of blow by lol. I also tried 0w-40 vs 0w-20 and the oil consumption was the same with both.
    So what I am going to try on this car is:
    1. Drill out the tapered upper pcv intake port to its full size to get rid of its taper and get the maximum port size out of it.
    2. Install a large straight fitting in place of the pcv valve down low to get the maximum port size out of it.
    3. I will probably use 5/8" heater hose to connect these to a vent to atmosphere catch can. Using the shortest distance possible for each hose for the least restriction.
    4. Dissassemble and remove spark plugs and intake manifold. Drain oil. Remove oil filter. Do a piston soak and valve soak and clean with e85, which i have found to be the magic fluid for cleaning carbs, fuel systems, fuel varnish of any age or level of stick, engine oil pan sludge (this stuff being related to the ls400 i just got running a week ago that sat for 13 years with oil and gas in it).
    1st round piston soak: I will do it for 24 hours and clean the intake valves and port since its easy.
    2nd round piston soak: Maybe 3000 miles later I will note oil consumption and see if it got any better and do the second piston soak for say a week straight instead. Baked on carbon is a bit more challenging for solvents than other things.
    Hoping that this will help free up the rings and reduce the massive amount of crankcase pressure the car gets at higher RPMs to reduce oil consumption. The pressure just overwhelms the rings. Also, the thinking on the EGR delete and routing the PCV system outside of the intake is i will get less carbon build up on the rings going forward.
    *A lot of the startup pinging is from the car sucking in oily blowby liquid that pools up in the bottom of the intake manifold will be gone. The design is just a bad design. The intake pools up oil in the direct air stream allowing turbulent air to kick up the oil to be picked up and brought into the cylinders. These are high compression cars so that will make the engine knock pretty hard. A better design would've been like every other car where the oil pools up in the intake at say the back or bottom of the manifold outside of the direct air stream.
    Disclaimer:
    1. If you have smog checks the car will fail from the PCV needing to be a closed system. If you route the catch can back to the intake BEFORE the MAF you will be a closed system. If you live outside of the united states in a country without emissions requirements you should be good to go!
    2. Any CEL code at all will fail a car on emissions testing in the united states so be aware of that.
    *Technically i guess you could connect the intake and exhaust ports of the pcv system into the intake system after the maf to avoid destroying the maf sensor. You just have to realize points after the maf are for already accounted air so if you pull one port from after the maf the other one will also need to return air after the maf.
    #1 Paladain55, Nov 14, 2022
    mikey_t likes this.
  2. Mendel Leisk
    42,315
    What’s the miles?
  3. Paladain55
    414
    172
    The South
    Low 200s. I'll have to go look at the dash for the specific number.
  4. ChapmanF
    18,999
    If the system is in fact clogged (no flow), then running with the valve unplugged (no flow) is not changing that condition, and therefore doesn't demonstrate clogging. However, unplugging the valve causes a P0403 code, which results in retarded ignition timing to protect the engine, and that change to the timing may noticeably affect how the engine runs.
    There is one kind of clogging you can diagnose this way, and that would be uneven clogging of the four intake manifold passages. With that, you can notice characteristic rough running that comes only at mid-loads where EGR is used, but not at idle or at heavy load, both conditions where EGR is not used. At the mid-loads, the valve opens, and then some cylinders get EGR too much, and others too little. If disabling the EGR makes such mid-load roughness go away, probably uneven clogging in the manifold is your culprit.
  5. Mendel Leisk
    42,315
    If you've got P0403 misfire code still, try swapping the coils/plugs around, see if the code changes. If not, points more-n-more to head gasket failure.
    My 2 cents: EGR/intake cleaning should be done much sooner, by 100K at the latest.
  6. Paladain55
    414
    172
    The South
    Yup already visited the egr issues so i agree. Thanks. Yes the engine can suck drops of liquid upwards a couple inches. Its more about how the tumbling turbulent air actually whips the liquid slightly and can pull drops upwards. I don't have that issue but sometimes we all get that early morning start up knock once a year or so.
  7. Paladain55
    414
    172
    The South
    P0403 is not a misfire code.
  8. Paladain55
    414
    172
    The South
    This isn't an EGR thread so reply to me in one of the other ones though. Thanks!
  9. ChapmanF
    18,999
    That's considerably more than a couple inches, as the photo shows. While I can see that you think the tumbling turbulent air is able to do that, significantly enough to be the cause of the startup knock, I don't see that you've laid out the evidence on which you think that, or why anybody else should think that—particularly as the startup knock occurs on startup, when RPM is low, throttle is not far open, and air volume and velocity are not high.
    For others following the thread and wondering about P0403, it isn't a misfire code, it's the detection of an electrical circuit fault in controlling the EGR valve. (Naturally, unplugging the EGR valve's electrical connector triggers the code.)
  10. Paladain55
    414
    172
    The South
    Its about 6" so in relative terms its a couple inches in my book. I get that its not exactly 2". Yup the code is from an intentionally unplugged egr connector. I cleaned the system and then left it unplugged. But the conditions you named off is when vaccum is the highest.
    *I was trying to copy and paste a pressure and velocity equation, but the higher the pressure differential the more velocity you get.
    #10 Paladain55, Nov 14, 2022
  11. ChapmanF
    18,999
    Vacuum is highest during engine braking, or when the throttle closes at higher rpm. It is modest at idle or startup, and low at full throttle.
    When the throttle is closed, there is a high pressure differential across the throttle plate and therefore a high velocity right there (of a very small volume of air). Once past that blade, it finds itself inside a manifold that's sized to carry a few thousand liters a minute at high loads. The trickle of air at startup and idle is nothing like that.
    If you're convinced that trickle can lift enough of that glop 6" into the cylinders to be the explanation of startup knock, can you describe the experiment(s) that convinced you?
  12. Mendel Leisk
    42,315
    Ah yeah: EGR related. My bad.
  13. Paladain55
    414
    172
    The South
    Okay second highest. I agree that the high rpm will create more vacuum than idle the moment the throttle body is closed again. But, there is zero vacuum at wide open throttle. Its definitely not a modest vacuum though. Take the lower pcv hose off and let it suck on your arm. It for sure has a lot of vacuum. And its not across the throttle plate its called manifold pressure for a reason. The whole manifold will have a vacuum lol. But it is like a 6hp shop vac or something comparable. My comparison is how i have cleaned the intake valves on the ls400 and was able to lift droplets out with my vacuum easier by creating a more turbulent air path. The reduction in pressure helps lift them and evaporate them as well.
    So the belows that robots use use a vacuum seal cup to pick things up. This is another comparison to how hard the intake manifold vacuums at idle. Also, 2010's have a nice amount of blow by so that also increases the pressure differential further.
    It makes sense though it ties in to the massive eliminate that start up knock catch can thread.
    The manufacturers do actually tune the cars to get a lot of vacuum on the crankcase though. Their goal is to decrease the pressure in the crankcase so there is less pressure differential between the upper piston and lower piston to reduce pumping losses and make up for blow by the added into the system as well etc... And then they tune that vacuum to work the best from idle closed throttle body and up. The vacuum benefit of the system going away as you get into the high rpms and the throttle body is open more and not creating as much vacuum...
    #13 Paladain55, Nov 14, 2022
  14. PriusII&C
    PriusII&C Active Member
    432
    147
    San Jose, California
    Oil consumption is reduced by a factor of 8x when <3000 RPM. That's a big difference.
    Paladain55 likes this.
  15. Paladain55
    414
    172
    The South
    Isn't it wild? The thinking here for me is: can I take away the tiny pcv valve which helps a lot at low rpms, to add some more pressure relief for the crankcase up top in the higher rpms through larger breathing hoses? Will it balance out to a net positive or a net negative increase in oil consumption or will there be no change? Don't know yet but i plan to test it as its all reversible pretty easily.
  16. ChapmanF
    18,999
    Exactly: the whole manifold has vacuum, meaning there is next-to-zero pressure differential within the manifold. The place there is a large pressure differential is right across the closed throttle plate, because there is near-atmospheric on one side of it, and 17 inHg or so of vacuum on the other.
    In this post you're talking more about vacuum, compared to your earlier post where you were going to copy and paste a PV equation:
    There is a place where the differential (and therefore velocity) is high, namely right across the throttle, and also a place where the vacuum is high while the differential (and therefore velocity) is low, namely within the manifold. It's important not to mix those up.
  17. Paladain55
    414
    172
    The South
    Ah yes i see what you mean. But you can put a vacuum port anywhere on the intake manifold and as long as it is behind the throttle body it will pull a vacuum. So my ls400 has a port on the back for the acis itb actuators, a port on the back for the brake booster, a port in the middle for the power steering idle up valve connections, and a connection for the pcv valve. I know they all have a vacuum but yeah i'm not entirely sure on the difference between them as there could some variance in available vacuum at each location like its inverse which is a pipe with pressure and it has varying diameters. I will say that and Manifold pressure itself is actually a measure of the vacuum pressure between the throttle and the cylinders which is the principle map sensors work off of. So... I still say since the intake valves are doing the sucking it is possible.
  18. ChapmanF
    18,999
    Yes, that's exactly as you'd expect, right? That's what it means to say that within the manifold itself there is next to zero pressure differential. The pressure (or lack thereof) is pretty much identical everywhere inside there. And that's why the airflow velocity inside there isn't much. Just as your PV equation would tell you.
    Now, at high throttle and high load, yes, there's a lot of air flowing through the manifold, so then you do see some real velocity, and some real pressure difference between the throttle end and the port ends of the manifold. Those just aren't the conditions at engine start.
  19. Paladain55
    414
    172
    The South
    Yes and no. I'm trying to say the pressure differential is between the intake valves and the manifold forward to every where else. But I say plausible. I use a vacuum to dry things and it pulls liquid up but yeah we aren't sure on the size of the drops so we will leave it as: Maybe? Not proven.
  20. Paladain55
    414
    172
    The South
    BUT I have to stop you there. Thats 100% wrong. There is no vaccum when the throttle body is open at high load. This is one of the reason why drag racers and others dont use pcv valves anymore as there's no vacuum at wide open throttle to take advantage of. It its greatest at closed throttle and diminshes to almost zero as the valve goes completely open. So its not something to be relied on for reducing oiling pressure as you get closer to wot.
