Gen 3 navigation database update?
Discussion in 'Gen 3 Prius Main Forum' started by Jim Caldwell, Sep 8, 2019.
  1. Jim Caldwell
    Jim Caldwell Member
    145
    26
    Mathis
    Just got a 2010 prius 3. In reading other threads here, the database is on a dvd which is read every time the car is started. but how can that be? When i ejected the cd player (does it even read a dvd?) For the first time, there was no disk in there. And if that was true, it wouldnt be able to play a cd and navigate at the same time. It must have hard drive or some non- volatile storage, and its just updated from a NavTek dvd? Or does the updste msybe have to be done at toyota dealership for a whopping 200.00?
  2. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    The nav info is on its own DVD, in a separate drive, so the update is accomplished with a new DVD (which ain't cheap).
    52,677
    under your seat
    Johnny Cakes likes this.
  4. ChapmanF
    18,880
    Gen 2 had the DVD under the seat. Gen 3 is different stories, because 2010 and 2011 had one choice for nav, where the DVD is in a separate slot below the CD slot (you need the screen folded out to see either one, and you need the right menu on the touch screen to tell it to eject the map).
    Later Gen 3s, 2012 on, had two nav choices, and one has an internal hard drive that's updated by copying from a USB key, and the other has a replaceable SD card that people occasionally post about dropping between the seat cushions or in some other evil spot.
    jakolp and Ed Beaty like this.
