Gen 3 prius 2013... code C1202 questions!
Discussion in 'Gen 3 Prius Technical Discussion' started by bagn, May 27, 2022.
  1. bagn
    bagn New Member
    FL
    Can the Code C 1202 Master res level malfunction cause the Accummulator to cycle and does this lead to the accumulator leak code? C1391. Brake fluid level full in reservoir that i can so ... so is there an internal reservoir in the Brake actuator.. could a faulty brake fluid level switch do this?
  2. Tombukt2
    Tombukt2 Senior Member
    13,864
    2,519
    Durham NC
    I'm sure the system must hold fluid from each cylinder all the way back through the actuator the accumulator all the way up to the reservoir of fluid that has to be complete and stay full if it goes down it needs to pull from the reservoir with no air so I would assume in the reservoir and accumulator and all those places there is brake fluid and no air in the system throughout I don't know how much the accumulator or the actuator would hold but you don't feel it separately I hope.
  3. ChapmanF
    19,027
    The C1202 is intended to warn you about low fluid in the reservoir, but if you are seeing a proper fluid level there, then it is probably an issue with the level switch or its wiring.
    That is probably unrelated to a C1391 or pump cycling; they'd just be separate issues. If the reservoir level really were very low (enough to allow air in), that could be a different story, but a simple issue with the level switch isn't going to cause pressure to bleed off.
  4. bagn
    bagn New Member
    FL
    thanks every one!!
