Gen 3 Rear Toe Out of Alignment
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Steven Tessler, Dec 19, 2020.
  1. Steven Tessler
    Steven Tessler Junior Member
    Georgia
    Have a 2012 Prius that has the driver side rear toe out of alignment. This car has rear disc brakes and I’m looking for how best to correct the problem. I’ve read that a shim can be used behind the wheel bearing, but what about on the brakes? Any help would be very much appreciated.
  2. tony_2018
    tony_2018 Member
    227
    68
    I questioned this method, the Fit uses the same rear beam.
  3. ASRDogman
    ASRDogman Senior Member
    8,069
    4,091
    You should check to see what is bent.
    If it is off, it's either bent or broken.
  4. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    The shims are readily available, and are the accepted method for correcting rear toe. Any competent shop should be able to do it.
    This video shows how it's done by a DIYer:
