Gen 3 transaxle failure/fix at 193,000
Discussion in 'Gen 3 Prius Main Forum' started by Jeremy J. Ford, Feb 12, 2020.
  1. Jeremy J. Ford
    Jeremy J. Ford New Member
    29
    St. Louis, mo
    Don’t have to straighten Me
    PriusGuy32, mjoo and Mendel Leisk like this.
  2. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    Were you able to straighten then and clean them to get them to work?
  3. Jeremy J. Ford
    29
    St. Louis, mo
    So here is the update: after swapping the plug,it cleared the p malfunction error. The problem now, it still won’t start as if the engine is locked. I know the engine is not locked. Without the transmission in it turned smoothly. It also turned when installed the transmission. But once I tried to start it with the error cleared, it locked up.
    here is my question, I the car was bought new from dealer. I called and got all the records emailed to me. Then I fount the record below. Look at the highlighted area.
    What are the symptoms of a bad investor. Does it lock up the mg1 and mg2 motors?
    Is there a way to test the inverter or just swap it out?
  4. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Wouldn't it be easier to check the codes?
    Pixel XL ?
  5. Jeremy J. Ford
    29
    St. Louis, mo
    I di
    i did. With techstream. Lost communication with hybrid system.
  6. George W
    George W Senior Member
    939
    520
    San Antonio
    It looks like the inverter was replaced. Is that what the term, remedied, indicates?
  7. Jeremy J. Ford
    29
    St. Louis, mo
    I think it was just flashed.
    Is the hv inverter the same as the hybrid powertrain control module?
  8. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Any updates?
  9. Jeremy J. Ford
    29
    St. Louis, mo
    Going to dig back into it tomorrow. Was waiting to hear if anyone knew if the hv inverter is the same as the hybrid powertrain control module?
  10. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    A quick google (' hybrid powertrain control module') seems to indicate that it's a separate item. May have things to do with the inverter, but it ain't the inverter.
  11. Jeremy J. Ford
    29
    St. Louis, mo
    Ok guys. I finally gave in, and had it towed to an independent shop. The diagnoses, the integration really burned up. He also told me, that shortened the hybrid battery. So, $300 to get my car back, but it still needs a hybrid battery. At this point, do you think that I can just rebuild the hybrid battery? I figure I can test and replace the bad modules.
  12. johnnychimpo
    johnnychimpo Active Member
    522
    112
    Monterey
    Did you get it going about to swap my transmission I have my pic of year. Going for a 2014 with 80k anything to look out for?
