Gen 4 12 Volt battery.
Discussion in 'Gen 4 Prius Technical Discussion' started by padroo, Feb 13, 2018.
  1. Mendel Leisk
    42,296
    Well, we OCD types balance it out: crawling over/under our cars, with cell phones at the ready and a pit lamp in our teeth. :D
    pjm877, bisco and Prodigyplace like this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I didn't realise it was see through. Here is a (poor) video - you can see the fluid moving in the top of the cell when I rocked the car. Unfortunately, my phone kept rocking at the same time
    Prodigyplace likes this.
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    That’s basically the situation: as I mentioned before, the Repair Manual (more info) says to check the electrolyte levels, as part of the on-vehicle inspection procedure for the charging system. Toyota writes:
    • If the electrolyte level is below the lower line, replace the auxiliary battery.
    • If the electrolyte level is below the lower line, add distilled water to each cell. Then, recharge the battery and check the electrolyte specific gravity.
    Standard Specific Gravity:
    1.25 or higher at 20°C (68°F)
    For the U.S. market, the Warranty & Maintenance Guide books don’t mention checking the 12-volt battery at all, and the Owner’s Manual books say only to “Make sure that the 12-volt battery terminals are not corroded and that there are no loose connections, cracks, or loose clamps,” though they also warn against the “poisonous and corrosive sulfuric acid.” There’s no discussion of checking levels or adding water.
    That’s not true everywhere. In Europe and Australia—where the cars use the same battery—the same sections of the Owner’s Manual books go on to explain how to check the battery fluid level and add distilled water, if necessary. The Maintenance Schedule for Europe, however, says “Battery: No maintenance.” For Australia, the Warranty and Service booklet lists “Battery” as an inspection item at every service, without elaboration.
    DonJuan1943, PtPri and alanclarkeau like this.
  4. alanclarkeau
    7,045
    7,593
    I never noticed before - but yes, it's reported as inspected:
  5. Mendel Leisk
    42,296
    They don't really mention level, in the above. Too: whenever I see those hit-lists, my skeptical sense kicks in.
    I'm out of that loop, doing DIY, and would advocate to remove the battery from the car, say around the 3 year mark, clean the posts and cable clamps, also the case, check the fluid levels, level them all up with distilled water. That should do it, assuming replacement around year 5.
    PtPri likes this.
  6. bisco
    52,803
    20 years of prius 12v issues, do other car sites spend so many kWh on this?
    krmcg and Raytheeagle like this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Other sites don’t have as much energy:p.
    PtPri and bisco like this.
  8. alanclarkeau
    7,045
    7,593
    I've posted this before:
    But I asked him a question yesterday about whether PRIUS Gen 4 should have an AGM or Wet/flooded 12v battery - basically he said ... how about you read it yourself - it's probably still the first comment to a question I asked in comments below the YouTube. My YouTube "name" is alanclarkeau - the same as PriusChat.
  9. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    Batteries live a tough life in either climate extreme. I keep gloves in my car. Not for when it's cold, but rather, for when it's common that the steering wheel is too hot to hold if the car is parked outside (shades only help so much...).
    My new 2018 (two weeks for me, but manufactured a year ago in January 2018) mysteriously came with a non-OEM battery, which itself is showing low-voltage indications. Tentative theory: the car sat outside through a long, hot Florida summer being only short-tripped only occasionally. That's a virtual recipe for battery (12v) trouble. Still in the investigation phase, so we'll see where it goes.
  10. Mendel Leisk
    42,296
    That reminds me: better go out to the garage and attach the smart charger, the car's more'n not being used today, could be idle the next few days as well.
  11. bisco
    52,803
    might as well change the oil while you're out there :p
  12. Prodigyplace
    12,710
    11,848
    Central Virginia
    And lube the brake pins. ;)
    krmcg, Mendel Leisk and bisco like this.
  13. alanclarkeau
    7,045
    7,593
    I've been using one of these in my car for 20+ years and use it if the wheel is in the sun - it makes it cooler - but still hot:
    Goes back to 1995 we bought a Mazda with 3 yr warranty, and just before the warranty ended, the urethane of the steering wheel became a little loose on the centre steel ring. They replaced it under warranty - but the mechanic warned me that the modern wheels need to be kept covered as they're not standing up to the heat of the sun, particularly in the tropics.
    Fast forward to 2008 when I bought my first car with a leather coated wheel (FORD), and I had the same advice - keep covering it, leather doesn't stand up to sun either, and they're still urethane underneath.
    I've tried shades, but they're more awkward to use, but do protect more than the wheel.
    Prodigyplace and Mendel Leisk like this.
  14. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Maybe there's none in it :whistle:
  16. alanclarkeau
    7,045
    7,593
    kithmo, Raytheeagle and Prodigyplace like this.
  17. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    They probably make left handed channel locks;).
    I bet if you go to the local auto parts store and ask for a set, they’ll point you in the right direction :LOL::ROFLMAO::).
    Ingenuity at its finest (y).
    kithmo, alanclarkeau and Prodigyplace like this.
  18. Mendel Leisk
    42,296
    Just take to not push the release lever, you'll be fine, lol.
    kithmo and alanclarkeau like this.
  19. Mendel Leisk
    42,296
    ^ Meant to say:
    alanclarkeau and krmcg like this.
  20. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
