Gen 4 12 Volt battery.
Discussion in 'Gen 4 Prius Technical Discussion' started by padroo, Feb 13, 2018.
  1. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    According to my careful read of almost all of the 740 pages of my owner's manual we are no longer at risk for a flat 12 V from lights left on. I think most everything that could be left on will time out after 20 minutes. Finally, technology to the rescue.
    PtPri, jerrymildred and krmcg like this.
  2. Mendel Leisk
    42,355
    I’ll believe that when I see it.
    krmcg likes this.
  3. Prodigyplace
    12,717
    11,849
    Central Virginia
    I do not trust the running lights to turn off on a timer. I set mine to turn off immediately.
  4. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Probably only the parking lights will stay on until the 12v goes flat.
    alanclarkeau likes this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Yes and no. I drive most of the daylight hours with parking lights (because I think it's more important to be seen from behind on a Motorway where I spend most time (and on my side of the road)) - and they turn off - they don't have a delay, but it's immediate.
    I have to manually turn to ON or AUTO for headlights at night.
    BUT - if I've got headlights on when I come in at night, I usually turn them to PARK as I come down the driveway (also so I don't alert the dog to me being home).
    One night, I forgot to flick them back to PARKERS, got out and [I think this is what I must have done] then reached back in and turned them to PARK. An hour or more later, my neighbour alerted me to my lights still being on. And the battery was too flat to start the system. I thought I'd rest it - went back an hour later and it had enough charge to start the car. I went for a drive - and sat with it in "D" for a while. That was 3 years ago - and the battery has been fine since.
    jerrymildred likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,170
    Tampa, FL
    True, as long as the technology works. My owner's manual confirms that they will eventually turn off, but also cautions not to make a practice of leaving them on so as to protect the 12V. (P. 517 in my manual)
    I'm not sure, though, if you don't get all the doors shut all the way of the lights will just stay on. So far, I've always noticed it when I didn't latch my door, but one of these days, I night not notice it.
    Also, I've seen lots of relays fail in my line of work, but so far, not in a car.
  7. Mendel Leisk
    42,355
    Door ajar is what nearly always gets me. Or map lights, passenger visor vanity mirror light, or....
    When you've been nailed so many times, you tend to get skeptical.
    (That last sentence biblical humour?)
    #167 Mendel Leisk, Dec 23, 2020
    PtPri, Prodigyplace and jerrymildred like this.
  8. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    Well, I will venture a guess that monitoring has tightened up for 2021. I even got an LCD meter warning (what they call the two center-mounted dashboard displays, vehicle speed, fuel level, odometer, mpg, etc. now) when the driver's side power window was down maybe an eighth of an inch from closed. I can't find that particular warning in the owner's manual yet. I'm only up to page 693 though.
  9. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    The owner's manual says those and even the emergency flashers will be turned off after approximately 20 minutes. I'll read it again just to make sure, but I think that is what I read.
    davecook89t likes this.
  10. alanclarkeau
    7,045
    7,593
    You can (or at least used to be able to) get the Manual as a download from TOYOTA US website - meaning you can do a search.
  11. jerrymildred
    11,517
    14,170
    Tampa, FL
    Yes, the manuals are still there. Searching a PDF file is sure a lot easier than searching a 35 pound paperback. :LOL:
    AzWxGuy and alanclarkeau like this.
  12. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    559
    Tucson, AZ
    2021 Prius
    Oh yeah, downloaded the pdf lickity-split. The only way to fly.
  13. alanclarkeau
    7,045
    7,593
    Just not as easy to read a laptop in bed. The book makes good bedtime reading - a few minutes, and :sleep::sleep::sleep:.
  14. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I don't know if your US light switch is different to our UK one, but my manual only mentions that all the lights will turn off if the switch is left in the headlight position, not the parking light position and no mention of the emergency flashers turning off after a time.
  15. alanclarkeau
    7,045
    7,593
    It's interesting the regional differences. I've been driving with ParkLights for probably 3 years or maybe more - and yes, they turn off. I haven't checked the book.
  16. jManfrey
    jManfrey New Member
    florida
    Three Touring
    i do not know if this has been posted yet in this thread but o'reilly sells a "140R" battery that is exactly the same size and seems to be working fine in my wife's prius. It was $150 at my local one
    Chris Wolfgram likes this.
  17. DonJuan1943
    DonJuan1943 Member
    64
    53
    Northern Illinois
    Enough of this! In the early 1960's they gave me a National Honor Society certificate. Not because I'm smart; but because I hung out with guys and gals like ya'll here. And I followed yall's advice. I bought new in 2016 a Prius 3 (grey), and I now I cannot think of a reason to part with it. New Michelines, 28000 miles, garage kept, unsmoked, unpuked, and nobody's ever had sex in it. I can find no reason to upgrade. But it has the original 12volt battery. I believe I'll upgrade the 12v battery. You've shown me why and how. Thank you all very much!
    krmcg likes this.
  18. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    So it was in this context:
    out in the middle of nowhere, with no sun protection, that I got:
    Luckily, having read you all discussing this, and mine being a 2019 in the heat... I ordered this eight days ago:
    And it saved my butt today.
    Thank you. This was the only store with one battery in the area. It was the $200 version, not the $159 version, but supposedly came with a three-year warranty. I bought it, and will install it later today or tomorrow.
    On top of saving me in the middle of nowhere, I've been able to get to the parts store, to the dog park, and back home on that jumper pack. So nice to have it.
  19. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    Seriously, today I feel like a won a mini-lottery having had that pack when I needed it the most.
    I'd strongly suggest anyone with a Prius consider getting a jumper pack, or carrying jumper cables, as their car approaches 2.5 years old.
    is the one that saved me.
  20. jerrymildred
    11,517
    14,170
    Tampa, FL
    Or any other kind of car, for that matter. :D
    Mambo Dave likes this.
