GEN 4 12v Battery BACK ORDER?
Discussion in 'Gen 4 Prius Main Forum' started by Tesh, Aug 2, 2021.
  1. Tesh
    Tesh Junior Member
    23
    Three Touring
    Prius fam, I NEED HELP. My gen4 12v battery died this morning and the Dealership said the batteries are on backorder and they have no idea when they will be in stock. Aside from using a portable battery starter what are my options?
  2. Mendel Leisk
    42,042
    Checked other dealerships?
    I believe there are still some aftermarket options? Paging: @Elektroingenieur
  3. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Where do you live? My two dealerships here are, also, out of stock but I found one in Denver (45 miles away) that has them in stock...so try calling the parts departments in dealerships starting with the closest.
  4. Tesh
    Tesh Junior Member
    23
    Three Touring
    Autozone has one, going to try that one out. I'll update this thread once I confirm it fits and works.
  5. Tesh
    Tesh Junior Member
    23
    Three Touring
    Toyota and AAA say these batteries from Toyota are gel batteries and that AutoZone or O'Reillys battery will die/explode. Can any one help validate please? I'm in a pinch!
  6. Mendel Leisk
    42,042
    Corporate Toyota? Who with AAA? I don't think Toyota uses gel batteries anywhere, and the fourth gen, besides a somewhat unique case shape, is an old-school lead-acid battery, being in the engine bay
    Tesh, PtPri and bisco like this.
  7. bisco
    52,525
    whoever you spoke with doesn't understand the difference between gen 3 and 4
    or between gel and agm. the auto zone battery is fine if it fits.
    your old battery may just need a charge
    Tesh, PtPri and Mendel Leisk like this.
  8. Tesh
    Tesh Junior Member
    23
    Three Touring
    AAA came through and tested the battery, he said it was dead. Plus once I turn it off, even after 30 minutes, the car does not start up. Battery is for sure dead, I dont think a charge will help. I have a 2016 Prius Touring 3, are we for sure that the Acid battery from Autozone or O'rielly's will work? I was told that it may die soon or explode.
    Toyota dealerships all over are telling me they are back ordered on this battery, idk what to do.
  9. Tesh
    Tesh Junior Member
    23
    Three Touring
    Battery is 20hr 45ah cca 295a if this helps
    PtPri likes this.
  10. esfishdoc
    esfishdoc Junior Member
    26
    45
    ESVA
    Charge the battery is my advice. It may go another couple of months... how do I know this? It's what has worked for me. Don't believe it is dead until it won't work in you car after a charge. AAA and anyone else who says so doesn't know what they are talking about in this case. Gen 4 are not AGM batteries. ( I've been shopping for a battery and some auto parts stores have looked up in there system and told me my car takes an AGM... they don't know their system is wrong)
    Mambo Dave, PtPri and Tesh like this.
  11. Tesh
    Tesh Junior Member
    23
    Three Touring
    Yup, definitely not an AGM battery. I finally replaced it with the acid battery from Autozone on my second trip there LOL.
    THANK YOU TO THIS FORUM!
    Mambo Dave, krmcg, ETC(SS) and 3 others like this.
  12. bisco
    52,525
    congrats! the misinformation in this industry is very sad
    Tesh likes this.
  13. MichelleStone
    MichelleStone Senior Member
    549
    818
    Mariposa, CA
    I had something similar to this happen to me a couple years back. I called a local parts place, Pep Boys, and even though they didn't have one, they chased one down for me and installed it. It too was pretty much an emergency situation and they came through for me. I waited at the dealership for two and a half hours before they told me they didn't have one. After going to Pep Boys, they had it installed within an hour.
    alanclarkeau, Mambo Dave and Tesh like this.
  14. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Its the same battery as a Chevy Spark. Its an unpopular one though. I read somewhere that the prius system needs about 50 Amps to power up everything to initially start it. Any brand of those jump starter packs and the new micro packs should be able to power the car from a drained battery. I think I even read somewhere of someone using a tiny 12v UPS battery in it in a pinch (wouldn't suggest this though).
  15. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    My car went for service yesterday - 100,000km/5yrs, though I've only done 65,000km.
    They mentioned that SparkPlugs were due on the 100k service - I almost told them to wait, but said "go ahead".
    Picked up the car "no Spark Plugs in stock, none in Australia, we've got them on backorder". I said that's fine - wait till next service or the next one.
    Mambo Dave and PtPri like this.
  16. robsnyder20
    378
    302
    SW Florida USA
    Thats crazy, everything seems to be out of stock and its sometimes the little things you don't expect. I think you should be good in yours. Its standard to go 100k between spark plug changes here in the US. That would be 163km. I have done them in previous cars at 90k miles here. Being that the Prii's motor only runs part time, I venture you could safely go beyond that but of course at $8-12 USD a pop, why not replace them early. Because we want to squeeze every last MPG out of that tank!
    alanclarkeau likes this.
  17. alanclarkeau
    7,045
    7,593
    Yep - my thoughts. I'm sort-of considering changing cars - but there's nothing which particularly appeals to me at the moment. PLUS - there aren't very many cars in stock for most brands - only cars which nobody particularly wanted anyway.
  18. esfishdoc
    26
    45
    ESVA
    Toyota dealer here in Norfolk/Virginia Beach area charges 25 dollars and some change for each spark plug. I went ahead and paid for them as I found it confusing if regular parts stores offer the exact equivalent. I haven't changed them yet. I think.. but don't hold me to it.. the normal recs are to replace at 120K miles. I'm up to 133K miles and running normally. Maybe this weekend I'll get around to it.
    As far as Battery: Pep Boys H 4 is an exact match for size... easy peezy...
  19. Mendel Leisk
    42,042
    I was a little incredulous of that, but yeah:
    (Nice schedule format btw. Waaaay easier to read than the american, event-by-event schedule. Canadian schedule looked like the above for a few years, commencing in 2014 IIRC. With the advent of 4th gen, they nixed all mention of the schedule, say something like "go to our website". There you find a supremely clunky event-by-event schedule, a myopic mess...)
    That's more reasonable. FWIW, the US schedule is 12 years or 120K miles.
    #19 Mendel Leisk, Aug 12, 2021
  20. PaulDM
    PaulDM Active Member
    616
    319
    UK
    2022 Prius
    Excel
    wow the Whole of Australia ?
