GEN 4 12v Battery BACK ORDER?
Discussion in 'Gen 4 Prius Main Forum' started by Tesh, Aug 2, 2021.
  1. bisco
    52,730
    spark plugs go early down under?(n)
    alanclarkeau and Mendel Leisk like this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Well, that's what the Dealer said. I don't doubt they might be able to scrounge some from another dealer if they were interested.
  3. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
    Still a good idea that someone goes in and breaks the plugs loose, then re-torques them. Leaving plugs in aluminum heads for 100,000 miles has been an expensive venture for a lot of folks when the threads the plugs were stuck to get pulled out. Plugs are usually steel, heads are aluminum these days. Current theory is to use anti-seize on replaced spark plugs.
  4. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    It's smart, when replace spark plugs, to have the car warm, not hot or cold. No need to put anti-seize on them, but some will put just a very small amount (like Permatex) on the edge of the plug where the coil sits (the white ceramic part.)
    One caution for everyone who replaces plugs is to GENTLY remove the electrical clip from the coil because the plastic gets brittle over the years. You have to squeeze one side then pull it off. It's smarter to use a little metal pick tool to lift the side on the coils up while squeezing the other. Having one break on you is a nightmare.
    Mambo Dave likes this.
  5. Mendel Leisk
    42,211
    Reduce torque maybe 25% if using anti seize (dry thread torque is 15 ft/lb).
    #25 Mendel Leisk, Aug 19, 2021
  6. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    Good points, gents.
  7. Ramo_958
    Ramo_958 Junior Member
    22
    Doylestown, Pennsylvania
    2018 Prius
  8. alanclarkeau
    7,045
    7,593
    Mine is 5½yrs almost.
  9. Ramo_958
    22
    2018 Prius
  10. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    Mines 5 years this past June. Resistance is getting high but its still testing good. Ill ride it till it dies since i have a portable jump pack and im curious how long this thing is going to go lol
