gen 4, 2021 backup camera
Discussion in 'Gen 4 Prius Main Forum' started by MikeV, Nov 11, 2023.
  1. MikeV
    MikeV Junior Member
    95
    philadelphia
    curious about the angle of the bkup camera. on my 2021 I can see part of the rear bumber and a sliver of the license plate. I dont recall that on my previous gen3 2010 model however that one didnt have the blue and red grid either. is this normal?
    52,855
    could be hd? idk for sure, but if you have a good view, it's probably fine.
  3. sylvaing
    sylvaing Senior Member
    1,221
    517
    If it's like my 2017, I hate that the white line aren't even close to the size of the car. When I park my car in the driveway (with a sidewalk beside it), the "white line" is about a foot within the sidewalk for the tires to be at the edge of the sidewalk.
  4. Mr.Vanvandenburg
    1,361
    660
    2020 Prius Prime
    I noticed that on my 2020 as I regularly back into a spot with white lines. It may be to account for mirror clearance in certain cases like backing up along a wall. Or getting by a fence post happily and then the mirror spoils the day.
  5. BiomedO1
    BiomedO1 Senior Member
    4,600
    2,414
    Left Coast
    IMHO, that backup camera is only good for making sure you don't hit the bumper behind you. No predictive or directional lines as your backing up.
    I installed a backup camera on my 2002 GMC SUV more than a decade ago. Paid $150, including a double DIN head unit display - even that had predictive/directional lines as I backed up. I get right under the trailer hitch, every-time.
  6. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    I have steering wheel angle lines on mine which are in yellow and move with the steering wheel and the blue lines show the current position of the wheels. I find I can get the car nicely centred into a parking spot pretty good using the camera.
  7. Harters
    335
    427
    UK
    Excel
    ** DUPLICATE POST **
  8. Harters
    335
    427
    UK
    Excel
  9. Mr.Vanvandenburg
    1,361
    660
    2020 Prius Prime
    I can see right to the ground to get the rear parking spot corners on pavement perfectly at the rear bumper. I don’t think it sees the license plate have to look again.
    I definitely don’t need more than the straight backup lines which correspond to the actual car body. I back in almost all the time for my free charging and my own home. My brain sees the path of the accurate car body lines, absolutely no problem getting in the spots perfectly, no benefit at all to have curved lines. The straight lines are a fixed reference, it’s actually better.
  10. sylvaing
    1,221
    517
    Here's what I meant. See the lines protruding over the sidewalk while my tires were just at the edge of it.
  11. MikeV
    MikeV Junior Member
    95
    philadelphia
    ok that looks like mine. i can see the top of your bumber I assume your car is blue and a sliver of your plate. the grid lines work well for me. i know i have about a foot beyond the red line
  12. Mr.Vanvandenburg
    1,361
    660
    2020 Prius Prime
    That allows for the mirrors. It should be like that.
  13. sylvaing
    1,221
    517
    Too bad they didn't put two sets of line, one for mirrors and one for the body of the car. When aligning with the sidewalk or even a curb, mirrors are irrelevant.
  14. Doug McC
    Doug McC Senior Member
    1,087
    428
    Midwest
    2022 Prius
    To answer your actual question: yes it is normal.
  15. sylvaing
    1,221
    517
    Ok, so while backing up to park by the road, I noticed that the passenger side camera line is actually in line with the curb. My right side tires were almost touching the curb and the backup camera line was right at that spot too. Odd that it's different for the driver side...
  16. sylvaing
    1,221
    517
    Ok, so I was backing up, not at home and the left line were where they needed to be, just over the curb, which was less than an inch from my tires. Only thing I can think off, the curb is higher than my sidewalk at road level and slant angle messes up the location of the lines.
  17. trailblazer55
    trailblazer55 New Member
    Miami, FL
    2020 Prius
    i noticed the same weird angle in my prius and it drive me nuts but oh well...wanted a prius..lol
