Gen 4 Amateur radio installation
Discussion in 'Gen 4 Prius Main Forum' started by AdamK, Jan 30, 2018.
  1. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    D-Star in the Prime.
    Icom ID-4100a fits nicely in the center console, control head on suction mount on windshield, and Diamond NR770HRKS glass mount antenna on hatchback.
    12 volt direct from battery.
    Works great, and no emi/rfi with any of the electronics at any power level, or during L2 charge.
    Usually on reflector 030C or 030B.
    73
    KI4EGQ
  2. Prodigyplace
    12,547
    11,772
    Central Virginia
    Are you sure it does not interfere with the vehicle's electronics?
  3. Locksmith
    Locksmith Member
    47
    65
    Vancouver, BC
    Technology
    I have 3 radios installed in my gen 4. Dual band mobile 50 watts, 220mhz 5 watts and DMR dual band 5 watts. I have even used them well auto parking my car. No problems at all.
    And, no, I don’t talk on all three at the same time. Two at a time is the best I have been able to manage. 8)
  4. crewdog
    492
    388
    Woodstock, GA
    I tested VHF, UHF, D-Star at all power levels while driving EV and hybrid mode over the course of a day, even while charging at a Chargepoint station; Nothing popped, fizzed or ordered Dominos on one-touch, so I'm satisfied that with the external antenna directing the RF energy that there is no harmful effect.
    Of course it will be good practice to check the SWR every once and a while.
    KK6PD likes this.
  5. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    I haven't done it in my G4 Prius yet, but on my Accord, I liked the simplest installation the best: mag mount in the center of the roof gets the signal out best. Trunk lid is lower, but not quite as good at getting the signal out. The signal radiates most evenly when there's an equal amount of sheet steel in all directions from the base. (Capacitive coupling to the virtual ground plane)
    I ran the cable just pinched in the passenger door seal, never had any leaks. The most challenging party of the installation was routing the cables in a neat way. I used zip tie bases, but they couldn't handle the summer heat. Made a mess to clean up when it was time to trade in.
  6. JohnTuro
    JohnTuro New Member
    Phoenix
    2018 Prius
    Is the radio head unit bracket attached to the underside of the dash using 2 sides sticky / mounting tape ?
  7. Locksmith
    Locksmith Member
    47
    65
    Vancouver, BC
    Technology
    I tried two kinds of tape including 3M trim tape. Nothing would hold. I decided that nobody was ever going to look at that surface so I drilled a couple of holes and put fender washers on the inside to spread the load over a larger chunk of plastic.
    It’s solid as a rock now.
  8. JohnTuro
    JohnTuro New Member
    Phoenix
    2018 Prius
    Tape alone would have been a easy solution.. Guessing you removed the piece to drill the holes ? If so do you have any instructions / tips to remove it ?
  9. Locksmith
    Locksmith Member
    47
    65
    Vancouver, BC
    Technology
    Tape alone wouldn’t hold. I tried a couple of different kinds. I only removed the shifter bezel so I could reach in to tighten the bolts. I drilled the holes without having to remove anything else.
  10. Larry Schulman
    Larry Schulman New Member
    Wisconsin
    Locksmith:
    This is my first use of Priuschat. I am K9IQ and I will be adding a VHF/UHF radio to my 2017 Prius 4. I am probably going to purchase the Icom ID-5100AE. I see how you mounted the antenna and I have a similar bracket to do the same. I will follow your method and use inserts to attach the bracket to car body. My question has to do with the mounting of the control head to the underside of the dash, as shown in the picture you posted. How did you attach your 90 degree control head custom fabricated mounting bracket to your car?
    I just purchased this used 2017 Prius and traded in a 2010 Prius. I had a Yaesu FT-8800 in that car with a dual band antenna mounted on the rear hatch. I hid the radio body in the trunk and powered the radio directly from the battery below through inline fuses. This car is going to be a bit more complex.
    73's
    Larry
