Gen 4 cells in a Gen 2
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TampaPrius.com, Jan 16, 2017.
  1. dingaling007
    dingaling007 Junior Member
    39
    Australia
    i-Tech
    Good advice thanks, do it right the first time as they say. Will order a wire frame #2 in that case.
  2. Donald Russell
    Donald Russell Junior Member
    uSA
    I've got an 07 Gen 2 that has several bad cells. I would like to put cells a Gthe from28 cells from a Gen 4 in the 07. Have been reading some of these articles. My question is if I go to a junkyard or call them how do I know which Gen 4 has NIMH batteries?
  3. nancytheprius
    nancytheprius Active Member
    365
    157
    iowa
    where are places that I can go about finding wrecked gen 4 nimh batteries to put in my gen 2? My hv battery is operational and I am confident that it still has some life in it. It is original tho, and I would definitely change the battery before failing if I was able to find one of these. (if it made sense price wise in comparison to a new gen 2 battery from toyota) It seems to be difficult to locate them on my google searches, but I can keep it on my radar throughout the next several months. Any feedback would be appreciated.
  4. nancytheprius
    365
    157
    iowa
    The two quotes below are ways to determine it is NiMh:
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    As quoted above, the Lithium batteries are much lighter. NiMH in a Gen 2 is over 80 pounds. Not sure of the Lithium, but it's substantially lighter.
    Also, you can look up the brochures. As I recall, the regular trim 2 (not the ECO 2) was NiMH for the first several years and all others were Lithium. Now the AWD version is the only one with NiMH.
    For example:
    2016 brochure:
    2019 brochure:
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    jerrymildred likes this.
  7. nancytheprius
    365
    157
    iowa
    mr_guy_mann likes this.
  8. Prodigyplace
    12,711
    11,848
    Central Virginia
    Trim Two ( NOT Two Eco) and, I think, Trim One from late 2017 onward.
  9. NotForTheBurnouts
    NotForTheBurnouts New Member
    Hi. Is the Prius V considered a Gen 3? Are the NiMH cells interchangeable with a Prius V?
  10. jerrymildred
    11,517
    14,167
    Tampa, FL
    The v is very gen 3. The hybrid batteries are interchangeable although I read somewhere that the 7-seat v uses Lithium.
    NotForTheBurnouts likes this.
  11. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I just bought a hybrid battery pack out of a 2017 Level 2.
    Has anyone installed one into a gen3? I'm wondering if the Gen 4 voltage sensor harness (a.k.a "wire frame #2" but for Gen3) is plug and play in Gen 3? I cannot find a new harness online to purchase.
  12. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    This is actually a really good question. I have a Gen 3 harness that was removed from a new Toyota Gen 3 HV battery. I also have a handful of Gen 4 harnesses. I think I need to put them side by side and see how they look.
    mjoo likes this.
  13. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    The gen 3 and gen 4 are not identical. The 2018 harness I just checked only has 10 sensing points/10 wires.
    mjoo likes this.
  14. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Ok thanks! They look almost identical.
    This gives me a good reason to buy a spare harness and prep it.
    #114 mjoo, Aug 14, 2022
  15. dingaling007
    39
    Australia
    i-Tech
    Just wanted to update this thread. My original gen2 prius hybrid battery pack has finally died. Previously I was going to upgrade the cells to gen4, but was able to get more life out of the original battery after balancing all the cells and putting new bus bars on. Well as of 27th May 2026 it drove its final kilometers before the RTOD and a total loss of power. This original hybrid pack is 18 years old!! (2008 prius) I'm very impressed its lived this long! I have a low mileage G9510-47130 pack arriving tonight that cost me $750AUD and a new Wireframe harness #2 coming from Japan($140AUD. So this Gen2 prius will live another 18 years hopefully
  16. JC91006
    16,936
    8,646
    I hope your "low mileage" replacement is from a newer car? Not a 2008 with low mileage
    Prodigyplace likes this.
