Gen 4 Center Caps
Discussion in 'Gen 4 Prius Main Forum' started by padroo, Dec 16, 2017.
  1. padroo
    padroo Senior Member
    2,763
    2,253
    2016 Prius Wheel.jpg I have seen this before but it's been a while.
    I removed the hubcaps from my Gen 4 2016 Prius and never plan on putting them back on again.
    I'm sure Toyota had some good reason to install those hubcaps but personally I thought they were ugly.
    The aluminum wheel under them didn't look good either mostly because they had no center caps. I looked
    around and found a low cost solution. Others have done this and now I have too, I ordered these
    1EMR6 Knockout Plug, Hole D 2 In, PK 10 from Walmart. They come in a package of ten and with shipping
    they were just over $8. I think they look OK.
    I used some hot melt glue to make them stick.
    RCO likes this.
  2. krmcg
    2,592
    2,393
    Whittier, CA
    It was worth $75 to me to get Toyota center caps.
    RCO likes this.
  3. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    1$ each for 1 1/2” electrical panel knock-outs, and some plumbers Teflon tape around them for a bit of friction
    RCO likes this.
  4. Mendel Leisk
    42,354
    Just editorial: it's always requires a mental "course correction' when I hear "hub caps", in the typical current usage. The "hub" is that little protruberance in the centre hole, and technically, a "hub cap" is a little cap, on that hole. What you're referring to as a "centre cap".
    A "wheel cover" is more recent innovation, a complete cover over (most typically) a steel rim, to dress it up, to masquerade as an alloy rim.
    Anyways, just rambling.
  5. padroo
    2,763
    2,253
    I am just using these for my winter wheels, here is what I have for summer.
    Click on the picture for a full size view.
  6. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
  7. Prodigyplace
    12,715
    11,848
    Central Virginia
    RCO likes this.
  8. Mendel Leisk
    42,354
    Yeah and why the eff would they do that? I know, to tick me off.
    RCO likes this.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    There's 'just fine' and there's 'refined.' Just me being petty. :sneaky:
    krmcg likes this.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
  11. Mendel Leisk
    42,354
  12. padroo
    2,763
    2,253
    I have thought about getting into 3D printing but center caps aren't enough to motivate me. lol
    How do they fit?
  13. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    In the old days when painted steel wheels were standard, the hub caps on most cars were expanded out to cover the lug nuts. So covering more than just the hub, but still called a hub cap from what I recall. Meanwhile more expensive cars like Cadillac had fancier stainless steel covers which covered the entire wheel, but still called a hubcap by most people, although I think I remember some people even back then starting to call those wheelcovers.
    I think the term wheel cover may have come into more popular use when plastic covers become the norm. Many people still call even the plastic ones hubcaps, which in a sense they are since they cover the hub, but for a traditionalist it's hard to accept the idea of a hubcap not being made of metal.
    #13 Since2002, Dec 17, 2017
    RCO, Mendel Leisk and Prodigyplace like this.
  14. Locksmith
    Locksmith Member
    47
    65
    Vancouver, BC
    Technology
    Care to share the printer file?
  15. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    RCO likes this.
  16. xcx
    xcx Junior Member
    SoCal LA County
    Do you still have these on your wheels? How are they holding up?
    I've been looking for quite sometime for oem or replica center caps that will fit my 4th gen but couldn't justify $80! LOL
  17. Mambo Dave
    Mambo Dave Active Member
    641
    307
    2019 Prius
    L Eco
  18. Mambo Dave
    641
    307
    2019 Prius
    L Eco
    I seem to be unable to edit that post, above, but those are the $9.99 center caps from ebay.
    Had to use the Dremel with a cutoff wheel to flatten all aspects of the locking nubs which weren't locking onto anything. In fact, they were pushing the caps out.
    Then used a non-permanent tacky stuff to hold them in. I really like the look of the silver center caps instead of the black & silver official Toyota ones that go for $80, but maybe that is in part because my car is white. With a dark blue Prius the black accents on center caps might be what I'd go for.
  19. Mendel Leisk
    42,354
    Exactly my issue, with some third gen caps. EBay listing said they were OEM. :rolleyes: Also, when I tried to leave a comment, for some strange reason couldn't: by design?
    Anyways, luckily I have OEM caps as well, and careful comparison and trial fit of both showed the issue: around the rim are four beveled zones. They're supposed to nicely center/secure the cap, but on the EBay ones the bevel is not sufficient, there's a flat zone just under the cap outside, and it raises the the cap accordingly.
    Half an hour patient dremel work:
    The translucent white zone is where I ground off material:
    Material removed:
    I kept at it, then trial fit, then grind some more. Basically had to go till that zone was completely beveled, before the cap would settle down, sit completely flush.
    #19 Mendel Leisk, Sep 19, 2019
    Prodigyplace and Mambo Dave like this.
  20. Mendel Leisk
    42,354
    One more thing: the jaws didn't lock positively in the groove inside the bore until I revised this bevel; they couldn't quite reach the groove.
