Gen 4 Engine into Gen 3 Prius Partial Guide
Discussion in 'Gen 3 Prius Technical Discussion' started by Alexander D, Feb 17, 2020.
  1. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    1. What are the misfire conditions?
    2. What does live data show?
  2. cexo
    cexo New Member
    Lithuania
    Live data shows cylinder 2 and 4bmissfires but very strange when i put in reverse the engine works better.
  3. Mendel Leisk
    42,343
    FWIW: in reverse only the electric motors propel the car.
    ZBrink likes this.
  4. cexo
    cexo New Member
    Lithuania
    Yeah, but engine still work when it's cold to reach operating temperature or when the battery drained to recharge the battery it wont stop the engine completely and misfire still occurs but not as much. Still as i see nobody has any ideas maybe other guys did the swap any sensors or something like that? Maybe i must keep the 4th gen fuel rail? Or maybe i just damaged the wire. :) no other explanation i can think of now unless i missing something but i didn't saw any post with the same problem.
  5. rjparker
    rjparker Tu Humilde Sirviente
    11,096
    6,962
    Texas Hill Country
    It is not crystal clear what your gen4/3 frankengine is made of. Egr 3rd gen. Head 3rd gen? Intake?
    Often diagnostic dead ends occur when someone assumes a potential cause is ok because of a faulty test or no test. Once the root cause has been “checked off” the guy does not return to it and finds himself at a dead end. Recheck everything including electrical, leaks and components.
    How did you block the egr flow? My first thought was egr flow at idle and low rpm.
    I would also consider pcv and vacuum leaks.
    Based on the seller and the cleanliness only?
    Do the misfire counters for both cylinders continue to increment all the time? Even at driving speeds over 30 mph/48 kph? If the misfire counter stops at speed it is more likely an egr/pcv/vacuum leak.
    Finally misfires changing cylinders on a hybrid can be one plug or coil but the misfires are incorrectly recorded on multiple cylinders. This can be due to engine speed fluctuations caused by a slipping transaxle damper. Very common with a head gasket coolant leak into one cylinder but can happen with an egr stuck open, pcv fault, vacuum leak or one bad plug,coil or injector.
    #145 rjparker, Oct 29, 2023
  6. cexo
    cexo New Member
    Lithuania
    I believe i found the problem. I left 3rd gen coils, because i simply couldn't fit the ones wich came with the engine(because of white plastic in picture). So tomorrow or the day after tomorrow i am gonna go and barrow 4th gen coils whitout that plastic and test how car will run. If the problem will stay i can go deeper to rewire everything and etc. I'm doing all this now out of curiosity.
    Egr clogging just with simple putty trowel, i test all priuses who have problem with cold start to eliminate egr as a problem you just put putty trowel between egr and egr tube and if the engine won't shake anymore you have to clean/change EGR
    #146 cexo, Oct 29, 2023
  7. ZBrink
    ZBrink Member
    82
    33
    Fairfax, VA
    I've been following skimmilkhybrid on Instagram (https://www.instagram.com/skimmilkhybrid?igshid=YzVkODRmOTdmMw==)
    He has done many Gen4 into Gen3 swaps and he says "tuning" after the install is required. He does this with Tech Stream software. Can anyone speak to this?
    I'm looking to do the engine swap myself but don't have the skills or knowledge to do tuning. I tried to ask him questions about the tuning and offered to pay him for either the tuning alone or his advice but he stopped responding on Instagram.
  8. Tombukt2
    Tombukt2 Senior Member
    13,858
    2,516
    Durham NC
    Well that's interesting tweaking maybe Not sure about tuning they're both two Z Atkinson cycle Toyota open deck engines I'm not sure what will be tuned but yeah maybe that's why he stopped responding because some folks win the questions start getting heavy they get lightheaded or something but usually not when you're throwing money at them so that's interesting but I mean think about it The generation 4 is just got some sleeves and some various band-aids applied . So I don't think tuning will really be at play here there's some different hose routings and things like that that come into play but my goodness that's a one time affair not really tuning per se.
  9. rjparker
    11,096
    6,962
    Texas Hill Country
    He is blowing smoke about tuning with Techstream. The real issue is getting different sensors and hoses to marry up. You have to run gen3 computers and networks. To that end, most use a lot of gen3 parts and pieces on a gen4 engine.
    chaddarack likes this.
  10. Tombukt2
    13,858
    2,516
    Durham NC
    That link doesn't even load.
  11. rjparker
    11,096
    6,962
    Texas Hill Country
    He is Drew Griffin and has posted here before about an Oklahoma based gen4 to gen3 mobile service. Recently he said too many problems were occurring after he traveled long distances and too many call backs. So he said no more mobile services but he might do jobs at his place in Oklahoma.
  12. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
    I feel that. Engine swapping even G3-G3 is not an exact science and nothing is equal in all cars. There are so many factors to get the swap running 100% smooth in all cars. A lot of liability with random check engine codes or new sounds that weren't there before. Customers need to understand this before going into it.
  13. Mendel Leisk
    42,343
    If I had a blown head gasket and likely knackered block, I'd be much more inclined to transfer my existing head to a brand-new (gen 3) short block, check/clean all, and reassemble with the Toyota gasket kit and new head bolts.
    douglasjre likes this.
  14. V Sport Wagon
    375
    131
    Southern California
    If you had money for the short block, it might be also wise to take your head to a machine shop who does heads and have them "clean it up" a bit and replace the valve seals...
    douglasjre and Mendel Leisk like this.
  15. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    No tuning required. They are blowing smoke. The Gen 4 engine acts and responds to the Gen 3 ECU commands as if it was installed there by Toyota.
    V Sport Wagon likes this.
  16. Tombukt2
    13,858
    2,516
    Durham NC
    Yes of course it does It's the same engine because you've added some sleeves and some dividers and a different set of rings I'm still the same engine bore stroke engine family running and duty cycle same That's why these things work and these kinds of swaps work because you're really changing nothing some underwear under the suit if you will.
  17. Mendel Leisk
    42,343
    There seems to be an overheating issue though. Maybe the coolant re-routing is a factor? Or are there 4th gen temp sensors swapped over, and they don't work well with the gen 3 computer programming?
  18. V Sport Wagon
    375
    131
    Southern California
    Coolant temp sensor wire extension is about it, and the slightly different single coolant outlet hose from the head. I don't have any cooling issues at all on mine, in fact it runs cooler than normal most times. Ever thought about the Gen 3 head option on a G4 block to eliminate the modifications?
  19. Mendel Leisk
    42,343
    That's what @cnc97 did; he's the pioneer, likely the first person on earth to do such a transplant. Soon after @Ragingfit chimed in, and provided a video saga of his second transplant: first was a gen 3 hatchback (IIRC), and then he did his Prius v.
    They're akin to Scott Carpenter and John Glenn respectively. :)
  20. V Sport Wagon
    375
    131
    Southern California
    With all do respect to them, there was a shop in Southern California that was doing it much before them likely...
