Gen 4 Engine Mystery blown head gasket.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by johnnychimpo, Dec 7, 2022.
  1. johnnychimpo
    johnnychimpo Active Member
    522
    112
    Monterey
    Background. I upgraded my gen 3 for a gen 4 engine to avoid the head gasket issues.
    But here I am. so I got this engine JDM when I got it it had a slightly bent valve cover gasket bolts
    no problem installed it ran great missed a hose clamp and it overheated pulled over added coolant
    and tightened the hose clamp fast-forward 20 k miles and 10 months of trouble free driving.
    I first noticed milky residue in the oil catch can no big deal lots of rain lately figured it was condensation.
    I noticed the car has been getting warm, not overheating but operating out of normal range. normal is 195.8 but now has been getting to 203 208F. I got gas this morning did my normal check oil while gas is added at pump.
    I notice the milky white goop on the dip stick MF! coolant is slightly low not much then I check the oil cap same and then hose on top that goes to the snorkel. Seems confirmed to me, head gasket blown. Now the mystery I don't have rattle start up so where else can the head gasket be leaking??????? All I can think of is this engine was in a car that was wrecked so bad it bent the bolts on the valve cover gasket and with the brief overheating it warped the head or caused the head gasket to move just enough for it to leak. What do you guys think this engine has 90 K miles
    52,594
    how many miles did you drive it before noticing a problem?
    certainly worth a leak down test to confirm
  3. johnnychimpo
    522
    112
    Monterey
    about 2k
    52,594
    maybe something was already wrong with it, any warranty?
  5. johnnychimpo
    522
    112
    Monterey
    I dont have the tools for that. any other suggestions.
  6. johnnychimpo
    522
    112
    Monterey
    I dont think so I would need to check doubt it, its been a year since I got it.
  7. johnnychimpo
    522
    112
    Monterey
    they dont warranty self install
  8. bisco
    52,594
    idk enough to suggest another way to test the hg. maybe just keep watching the coolant, and make sure it's not leaking somewhere
  9. johnnychimpo
    522
    112
    Monterey
    So where can this goop be coming from its in the engine. all over the valve cover gasket in the oil dipstick. Coolant was low just slightly. I just noticed since the last oil check so not that long ago.
  10. bisco
    52,594
    any white smoke? would gasoline cause the white? how do the plugs look?
  11. johnnychimpo
    522
    112
    Monterey
    no white smoke going to pull the plugs today. Like I said I think this is super early as there is not rattle startup and barely any coolant gone to confirm it is barely low. Im working on the leak down tool what should the presure be at??
  12. Paladain55
    Paladain55 Active Member
    413
    172
    The South
    So you replaced the engine to avoid head gasket failure or you had head gasket failure? But yeah man if you overheated the car once chances are the head gasket is already a goner. Especially if you have the froth every where. Try the coolant sniffer test and the leak down test. If you fail it looks like you can do a head gasket too. You will have to check the block and head for warpage above the acceptable limit when you do. Should be good to go after a head gasket though. Try not to drive too much with the bad head gasket. Its terrible for the motor.
    Also, the head gasket issue is completely avoidable. EGR system cleanings or disabling the egr system are the requirements for avoiding head gasket failure.
  13. Mendel Leisk
    42,093
    Seems like a lot of reports, with gen 4 engines transplanted into 3rd of overheating. @Ragingfit mentions to cut the jiggle pin on thermostat, not optimum maybe, but helps?
    That doesn't sound good. Change the oil and continue to monitor?
    You have a leak-down test gauge set?
  14. johnnychimpo
    522
    112
    Monterey
    it half pulled appart already. what is the warp tolerance for the head to get it or not get it machined.
  15. Mendel Leisk
    42,093
    Not 100% sure the cyl head one has warp spec. Will check. It might be same as block? That spec is noted.
    Addendum: cyl head warp specs in that third one.
    #15 Mendel Leisk, Dec 7, 2022
  16. ChapmanF
    18,797
    I have had, over the years, a few random passing incidents of a bit of froth on the filler cap and dipstick. It can happen when the weather conditions are just right for some condensation to form in the crankcase. If you can wipe it away and it's not a recurring thing, and there are no other reasons for suspicion, that can be all it is.
  17. johnnychimpo
    522
    112
    Monterey
    to confirm im thinking of connecting air compressor into the cylinder and see if I get bubles in the coolant tank. would this be a good test?
  18. ChapmanF
    18,797
    Not sure. Head gaskets can fail (supposing, just for now, that's what happened) in different ways. They need to keep coolant away from oil away from cylinders. If a gasket fails between a coolant passage and a cylinder, your test would give you coolant bubbles. If it fails between a coolant passage and an oil passage, you could get milkshakes but no bubbles from this test. And so on.
    What you're talking about is essentially a leakdown test without the leakdown tester. If you were doing a leakdown test, you could concentrate on which cylinders gave concerning readings, and then listen (manifolds, crankcase, coolant) for sounds of where the air was going.
  19. johnnychimpo
    522
    112
    Monterey
    copy that. I got the tool for the job so I will do this tonight.
  20. johnnychimpo
    522
    112
    Monterey
    So I pulled the plugs and they are clean. I got the leak down test tool and used it to blow air into the cylinders and held it with a wrench as the compression was trying to crank it over. in any case no air bubbles in the reservoir tank. at this point no sign of blown head gasket. is there any other place where oil and coolant can mix? Im out of ideas, if you have a suggestions im all ears. Im going to put it back together and just monitor the coolant. I will also change the oil. I take it if contamination is serious I would see water come out when I drain the oil right?
