Gen 4 Prius air filter. Where to get Toyota OEM
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by TinyTim, May 20, 2019.
  1. TinyTim
    TinyTim Active Member
    366
    224
    Seattle
    I think I am up for the task of changing my own air filter. It's up there with changing a light bulb. Where can I get the best air filter for a fair price? Or a better question. Which is the correct and best air filter for My 2017 Prius 2
  2. stewie3128
    stewie3128 Junior Member
    17
    Los Angeles
    2018 Prius
    Do you mean the cabin air filter?
  3. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,321
    Central Virginia
    I usually order mine either from Amazon or Olathe Toyota.
  4. TinyTim
    366
    224
    Seattle
    A link
    Yes, the Prius cabin air filter near the glove box.
  5. Mendel Leisk
    38,875
    Walk up to the parts counter at dealership, tell 'em you need an air filter (engine or cabin). They'll ask you a few questions regarding your vehicle, or if it's in there already, maybe just your phone number.
    Still: check the one that's in there first, verify it's in need of changing.
    The cabin filter still in our 2010 was put in at the factory. Ditto for engine filter. That's with a mere 50K miles, but yeah, both still viable.
  6. stewie3128
    17
    Los Angeles
    2018 Prius
    This is what I used in my 2018 Two - carbon filter, works great.
  7. TinyTim
    366
    224
    Seattle
    Anybody have an ebay link to the cabin air filter for Gen 4 Prius 2?
  8. Elektroingenieur
    2,515
    3,264
    Three Touring
    TinyTim likes this.
  9. Elt31987
    Elt31987 Active Member
    205
    149
    Derry, NH
    I get the TYC 800208C from Amazon. If you order enough from RockAuto it will be even cheaper than Amazon
  10. PriusPeep
    PriusPeep Member
    98
    68
    New Jersey
    I replaced both the cabin and engine air filters myself. It takes about one minute each.
    I bought both at the dealer because there are just too many cheap imitations. Saving five bucks is not worth it. I paid approximately $45 for both.
    I do recommend that you look up the price of the part on the Toyota site. Many dealers will try to sell it to you for more unless you show them the price on the Toyota parts site.
  11. WisSailor52
    WisSailor52 Junior Member
    Neenah, WI
    I order either a Fram or Wix equivalent filter from Rock Auto.Cheaper than a dealer.
  12. Striker325
    Striker325 Junior Member
    25
    24
    Los Angeles
    Engine Air Filter Toyota Part Number: 17801-21060
    Cabin Air Filter Toyota Part Number: 87139-28020
    You can find it on Ebay or a direct parts online re-seller.
    TinyTim likes this.
  13. TinyTim
    366
    224
    Seattle
    Just finished changing my engine air filter and cabin air filter. I went the Amazon route for both. The engine air filter quality was the same for generic. The cabin air filter for the generic was actually better quality than the genuine Toyota filter. I got the carbon air filter color like the genuine Toyota filter for cabin air.
    The engine air filter didn't look all that bad. The cabin air filter wasn't quite nasty looking, but definitely needed to be changed. The cabin air filter was original. 34,000 miles on the Prius.
    My question. Does Toyota replace the engine air filter once before the bumper to bumper warranty runs out? It didn't look bad but the hinges on the engine air filter compartment were stiff almost like they had never been touched since coming out from the factory in Japan.
    Here are the part numbers as provided by Striker325 for Prius Gen 4 air filters engine and cabin. I like to make online notes for google search engine.
  14. Elektroingenieur
    2,515
    3,264
    Three Touring
    The Warranty & Maintenance Guide (PDF) states that the first replacement is at 30,000 miles or 36 months; except under “Special Operating Conditions,” defined in the Guide, the filter wouldn’t have been inspected or replaced before then, unless the dealer checked it because they hoped to sell you a new one.
    As you may know, the basic warranty (which expires at 36,000 miles or 36 months, whichever comes first) doesn’t cover air filters or other maintenance items at all, and ToyotaCare no-cost service—at least according to the current program brochure (PDF)—ends at 2 years or 25,000 miles.
    TinyTim likes this.
  15. TinyTim
    366
    224
    Seattle
    Based on the stiffness of the engine air compartment and fittings. I thought it had never been opened. The Cabin Air filter wasn't all that bad but definitely could benefit from cleaning. The dealer only mentioned the cabin air filter on my last visit. I told them I would take care of that myself.
    I will watch the MPG now. I doubt I will see any change but will update the forum with my fuel economy.
    Thanks for the feedback!
    Elektroingenieur likes this.
  16. Mendel Leisk
    38,875
    Mpg may be slightly better with with a filter with some build-up? The air flow being a bit restricted, it's like you've reduced the engine displacement?
    Both the cabin and engine filter, I figure the change interval should be when they're good-and-ready to be changed? At 85K and over 9 years, our (original) engine filter in particular, looks virtually new, until you look at it on a shallow angle: then you can see some dark deposit, but really minor.
    #16 Mendel Leisk, Dec 12, 2019
    TinyTim likes this.
  17. Elt31987
    205
    149
    Derry, NH
  18. TinyTim
    366
    224
    Seattle
    Elt31987 likes this.
