Replace Cabin Air Filter
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Rangerdavid, Jan 24, 2017.
  1. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The first I came across was in the 2005 JB KIA Rio - that's the one I asked to see when it was being replaced - filthy.
    I'd had a couple of older cars which we removed the A/C Evaporator - the build-up of dirt, dust and odd stuff I suspect was grass seeds etc makes me happy to have a filter.
    Does anyone know if the filter is before or after the heater/a/c block on PRIUS?
    RCO and Mendel Leisk like this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    That's a really good question. I hope someone knows.
    RCO, alanclarkeau and Mendel Leisk like this.
  3. Mendel Leisk
    42,386
    Off-topic, but kind of similar: on our house's forced-air central heating, I put in replacement grills on all the return air intakes, that have filters. You're supposed to change them yearly; I was doing that, with the occasional vacuuming within that year. Now I've figured they look about the same as new after vacuuming, I'm stretching the year interval. Anyway, between the introduction of those filter, and the sealing campaign I mounted on the all the ductwork: the regular filter at the furnace never gets dirty.
    RCO and alanclarkeau like this.
  4. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    Keeps your ductwork clean, but now you've got to clean all these filters rather than one.
    alanclarkeau and RCO like this.
  5. Mendel Leisk
    42,386
    Yeah, it's easy though: the grills are hinged. Four in total, maybe 3 times a year.
    The duct system when I first looked into it, was incredibly "porous". Also had some "Escher" elements, ie: unconnected, nonsensical branches.
    RCO likes this.
  6. mdmikemd
    mdmikemd Member
    436
    Minneapolis
    I got so tired of being tracked down at the dealership and have to say that I didn't want to change filters. Eventually, I bought a cheap filter from Pep Boys and would change the filter at every oil change just so they would leave me alone. In the parking lot, I would put the better one back right away.
    RCO likes this.
  7. krmcg
    2,592
    2,393
    Whittier, CA
    What are the filter part numbers? Engine and Cabin please. Dense (Toyota) and any others that are actually correct fit?
    Thanks so much!
  8. Tideland Prius
    16,684
    lol. Yes it can be filthy in 6 months. Ask me how I know :eek: :cry:. I try to take it out, empty out the loose dust/sand/insects to extend the interval. Some places take a year and some 6 months. It depends on your environment. A place that uses a lot of sand (instead of salt) in the winter can leave a dusty filter (among other contaminants)
    It might be the minimum charge (charge in 1/2 hour intervals).
    I don't wash mine. I'll just knock out the loose dirt and maybe if I have a vacuum handy, I'll vacuum it. Otherwise, I'll change it every 6-12 months depending on how bad it looks.
    RCO, Mendel Leisk and alanclarkeau like this.
  9. Mendel Leisk
    42,386
    I believe you tideland. It just gods country here. :whistle:
    Actually, I think we broke record for rainfall in March, as of today: must keep the dust down
    RCO and Tideland Prius like this.
  10. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    I found this awhile back on the Toyota site. It maybe of help providing it's accurate which I presume it is...
  11. Prodigyplace
    12,720
    11,852
    Central Virginia
    I recently bought filters online from a dealer. I can check when I get home.
    krmcg and Sooner Al like this.
  12. Tideland Prius
    16,684
    To add more information to Sooner Al's post:
    The standard Toyota cabin air filter is a "dust & pollen" filter. The "premium charcoal" Toyota version is a particulate filter. Depending on the area you live in, a dust & pollen filter might work well. If you're in an area with a lot of industrial buildings (by area, I don't mean neighbourhood but more like city-size cause pollution does travel a good distance) or a place that uses sand for winter grip or a place that has a higher concentration of diesel vehicles (usually goes hand-in-hand with the industrial buildings but not always), then perhaps consider a particulate filter.
    Here in Canada, the aftermarket ones used to be particulate filters for the same or less price than the OEM dust & pollen filter. Canadian Tire changed their cabin air filter model to FRAM cabin air filter. It works down to 5 micron (particulate filters will work down to at least 2.5 microns which is the size of soot, certain types of dust and allergens).
    pilotgrrl likes this.
  13. Prodigyplace
    12,720
    11,852
    Central Virginia
    The cabin filter on my 2016 looks like a carbon one, so I would assume it is more than a dust filter. I have not checked my new one.
    Stupid typo and no edit. 2017 not 2016.
    I need to verify what I purchased. Since the dealer did not list 2017, I chose 2016 Prius. The new filter is not a carbon filter, so I need to verify the part number. Here are the Toyota parts I got.
    Cabin filter: 87139-28020 Element, Air Refiner
    Air Filter: 17801-21060 Element, Sub-Assembly
    #53 Prodigyplace, Mar 29, 2017
  14. Mendel Leisk
    42,386
    This is our original engine filter, at 66,000 kms, been in there since the car was built, in August 2009:
    Looks almost new to me. (n)
    RCO likes this.
  15. Prodigyplace
    12,720
    11,852
    Central Virginia
    How does that help us with Gen 4?
    krmcg likes this.
  16. Mendel Leisk
    42,386
    I guess what I'm trying to say: don't be too hasty in ordering filters, they can last.
    Didn't realizing I was intruding on an exclusive fraternity btw.
    RCO, kithmo and Prodigyplace like this.
  17. Prodigyplace
    12,720
    11,852
    Central Virginia
    Sorry. Your posting appeared right after mine about part numbers. Since your picture appeared to have a part number, I mad a faulty assumption.
    Most of us do not live in the clean country of the north :D
  18. Tideland Prius
    16,684
    Ohh you're talking engine air filter. I was talking about the cabin air filter. :oops: lol.
  19. Mendel Leisk
    42,386
    Well Prodigy mentioned getting engine air filter for his 2017; I couldn't resist.
    The cabin filter does seem to get dirty faster, but not much riding on it.
    RCO likes this.
  20. Elektroingenieur
    2,515
    3,288
    Three Touring
    The clean air filter is after the inlet control damper but before the blower and evaporator. Both fresh and recirculated air pass through the filter. (See the “Mode Position and Damper Operation” diagram in the air conditioning section of the Repair Manual.)
    Though it says it was updated for 2016, the “Air & Cabin Filter Information” document from Toyota kindly shared by @Sooner Al is out of date, since it lists the same part numbers for all 2010 and later Prius cars; the fourth generation definitely uses different filters.
    The part numbers from @Prodigyplace agree with Toyota’s parts catalog, which says they are common to all fourth-generation (ZVW5# series) Prius cars worldwide. The prices below are U.S. and Japanese list prices.
    Clean Air Filter (Cabin Air Filter)
    As @Tideland Prius notes, Toyota sells two versions of the clean air filter, the original one and a more expensive charcoal-impregnated one. See bulletin T-SB-0142-13, “HVAC Odor Maintenance,” for when to use the latter.
    • 87139-28020 – Filter, Clean Air (Pollen Filter, OE Part) ($20.99, ¥2,000)
    • 87139-58010 – Filter, Clean Air (Deodorant Filter) ($50.15, ¥4,000)
    Aftermarket substitutes:
    Engine Air Filter
    • 17801-21060 – Element Sub-Assy, Air Cleaner Filter ($18.00, ¥2,600)
    • Nippon Micro Filter Co., Ltd.: A1433
    • Pacific Mfg. Co., Ltd.: PA-1806
    • Toyo Element Industry Co., Ltd.: TO-192
