Gen 4 Prius RPM gauge is missing?
Discussion in 'Gen 4 Prius Main Forum' started by reddogpatch, Dec 11, 2017.
  1. reddogpatch
    reddogpatch Junior Member
    37
    17
    Savannah, Mo
    Three Touring
    Trying to find the Prius engine's RPM gauge...
  2. Zardoz
    Zardoz Member
    86
    52
    Show Low, AZ
    There isn't one
  3. reddogpatch
    37
    17
    Savannah, Mo
    Three Touring
    While I find that a rather odd omission on Toyota's part . It is what it is...thanks.
  4. Fester
    Fester Active Member
    201
    198
    Ohio
    Although a bit pricey a lot of us use a scan gauge II from Linear-Logic to display RPM and many other bits of data like temperatures, voltages, current, and even now individual tire pressures and temperatures. Their customer service and support is excellent.
  5. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    You can also get one of those cheapo obd2 adapters and connect it to your phone using torque or some other app for a lot less. I own a scangauge and they are awesome, but given how cheap the obd2 adapters are nowadays, this is the cheapest solution. Once you get an idea how the car runs, really the RPM's don't matter a whole lot other than for informational purposes only. FYI I owned a manual before, so no tach is a bit annoying at first.
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Here's a hybrid with a Tachometer:
    but at $250,000+ it's in a different class.
    I believe that PRIUS never had a tachometer, plus I don't see the point of having a tachometer - what would you use it for. It's not like you'd be matching revs to double de-clutch. They forgot the clutch for that. With Hybrid SYNERGY Drive, there is nothing you can do which, having a tachometer, will affect.
    As far as I know, no TOYOTA Hybrids do (Corolla or Camry) nor LEXUS hybrids either. I believe IONIQ doesn't either, even with a Dual Clutch transmission.
    I think VOLVO XC-90 and AUDI eTRON et al have a tachometer, but they're 2-3+ times the price of a PRIUS.
    The BMW I had on my shortlist when I bought PRIUS didn't either:
    RCO likes this.
  7. GT4Prius
    GT4Prius Active Member
    530
    412
    Cumbria, UK
    Excel
    I can't think of any circumstances in which I would need one. ? Confused ?
    The car will not let you rev it too fast and the hybrid system controls the engine speed when driving. And it's not a stick shift.
    So even if you knew the engine speed you couldn't do anything to change it except perhaps by driving more slowly.
    kithmo, alanclarkeau and RCO like this.
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  9. alanclarkeau
    7,045
    7,593
    This website has a good simulation of the relationship of MG1, MG2 and the ICE.
    Toyota Prius - Power Split Device
    I think my first 4 or 5 cars didn't have tachometers, and without synchromesh on first gear on the first 2 - but you soon learned to match the revs by ear. I think 13 of the 14 cars since - prior to my PRIUS had tachometers.
    One thing I've noticed is that cars are deleting more and more gauges - I only remember 2 of my early cars with Ammeters and one with a Voltage Gauge - 4 decades ago, I haven't had an Oil Pressure Gauge for at least 30 years, Vacuum Gauges seem to have disappeared in the mid '80s, and my last car, a FIESTA didn't have a Temperature Gauge.
    I suppose, when we make the transition to Autonomous Cars, the only gauge we'll have is one of these
  10. bisco
    52,857
    some people are just curious, others use it for pulse and glide.
    Geo Dude likes this.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I started driving a 1962 Ford Falcon 2 door station wagon, with 3 on the tree, the only gauges I recall was fuel and water temp.
    My wife's current vehicle, a Chevy Tahoe, has tach, oil pressure, water temp, fuel, and voltage.
    Vacuum gauges were important when we had carburetors, less so with fuel injection.
    The sender for oil pressure of a Prius is digital, you either have some or you don't, so no gauge is possible without an additional sender.
    I add tach, intake air temp, water temps and instant MPG. (dash uses tank MPG, and has outside air temp)
  12. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    The prius PHV GR sport and Prius α GR sport in Japanese market do come with tachometer, too bad it's not available elsewhere.
    CoolPrius likes this.
  13. Prodigyplace
    12,713
    11,848
    Central Virginia
    RPM for MG2, ICE, or both?
    Prime would need to add MG1 too, I suppose since it can be used for acceleration.
    MG2 is the main component driving the wheels with assistance at time, by ICE (& MG1 on Prime).
    RCO likes this.
  14. ea8631
    ea8631 Member
    186
    Toronto, Ontario
    Technology
    I think it is for ICE. Also, I just remember for Lexus CT200h when you are sport mode, the tachometer for ICE will appear to replace the power gauge.
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    MG2 is absolutely linear with wheel speed, so to some degree your speedometer is a Tach for MG/2.
    fuzzy1 likes this.
  16. Mendel Leisk
    42,348
    Ultimately, I don't much miss it. Pretty much any modern, computer-controlled automatic transmission car, it's window dressing. I really do miss coolant temp though, used to be a standard gauge, on every car.
    alanclarkeau, RCO and CoolPrius like this.
  17. CoolPrius
    CoolPrius Active Member
    218
    291
    86
    Virginia
    2018 Prius c
    Really like those interior GR touches. The silverish radio surround is probably much easier to keep clean (a textured surface would also work). Add the bone china console and I'm sold. Too bad we probably won't get those upgrades here in the states.
  18. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    2013 ford Cmax hybrid
  19. bisco
    52,857
    reformed smoker.:cool:
    RCO likes this.
  20. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    The tachometer on the GR is for bling only. It has NO other use! YOU cannot control the engine RPM other than by speeding up or slowing down or trying to accelerate faster or slower. In a Prius there are no gears to shift, and no eCVT points to program or switch between.
    But if the bling factor makes you happy buy a "Scangauge". It displays RPM if you like. Among other, more useful things. ;)
    RCO likes this.
