Gen 4 Prius shift knob adapted to Prius v
Discussion in 'Prius v Accessories and Modifications' started by Georgina Rudkus, Feb 20, 2019.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,571
    2,602
    Taylors, SC
    wheelz1980 and Brabus82 like this.
  2. Brabus82
    Brabus82 Junior Member
    Taylors, SC
    2015 Prius v wagon
    I like it! Did it screw straight on or did you have to make an adapter?
  3. Georgina Rudkus
    3,571
    2,602
    Taylors, SC
    shift knob w-stainless insert.JPG My husband's friend, a retired aerospace machinist made it for me. He has made many Prius"v" modifications for me.
    It had to be precisely bored out to a specific depth.. A special stainless steel sleeve was machined and pressed into the cavity.
    It fits perfectly and is correctly spaced to function like the original on the "v."
    #3 Georgina Rudkus, Aug 5, 2019
    Brabus82 likes this.
  4. ChapmanF
    18,996
    Is the original v shift knob backlit the way a Gen 2's is?
    This one doesn't look like it has the light pipe opening around the shaft.
  5. Centerpunch
    Centerpunch Active Member
    150
    139
    OH / NC
    2017 Prius v wagon
    I saw this thread a couple years ago, and then discovered and purchased a modified Prius knob for my previous white Prius v.
    I recently bought a 2017 silver Prius v, and discovered an easy and cheap way to adapt a normal Prius knob (with 8mm threads) to our 6mm shaft.
    I simply unscrewed the standard Prius v shift knob (which I find tiny and weird), cleaned the threads on the shift lever, and screwed on one of these adapters.
    Then I bought a 2019 Prius knob on ebay, and it screwed right on.
    2019 TOYOTA PRIUS SHIFT KNOB GEAR CENTER KNOB OEM | eBay
    I have 4 of the threaded adapters left, message me if you want one and I'll mail it to you.
    #5 Centerpunch, Dec 30, 2021
    icyrius and Georgina Rudkus like this.
  6. Georgina Rudkus
    3,571
    2,602
    Taylors, SC
    Are the 8mm threads M8x1.25 or M8x1.0? The threads on the shaft of the Gen 4 shifter are M8x1.25.
  7. Centerpunch
    150
    139
    OH / NC
    2017 Prius v wagon
    The threaded adapters from the Amazon link above have internal M6x1.0 threads to fit the Prius v shift lever, and external M8x1.25 threads for the Prius Gen 4 knob to thread onto.
    Georgina Rudkus likes this.
  8. Georgina Rudkus
    3,571
    2,602
    Taylors, SC
    Thanks, I just consulted with my husband's dad's friend who modified the Gen 4 knobs. Putting an M6x1.0 thread inside an M8x1.25 stud is very difficult tn machine. The threads must be rolled onto an M6x1.0 threaded sleeve.
    Nice find.
    #8 Georgina Rudkus, Dec 31, 2021
  9. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    My 2013 Prius v's shifter head has lost a lot of its silver paint after 106k miles. As an Uber driver, I use the shifter a lot more than most people do. I might consider doing this, just to get a nicer looking shifter head.
  10. Georgina Rudkus
    3,571
    2,602
    Taylors, SC
    Yeah, the Gen 4 shift knob has a durable rubber vinyl covering instead of the thin silver painted white plastic like the OEM v knob. The black grip covering is all the way through, so it will not rub away, It is a much more durable design.
  11. Centerpunch
    150
    139
    OH / NC
    2017 Prius v wagon
    If you want my mint original shift knob, message me your address and I’ll drop it in the mail.
  12. Centerpunch
    150
    139
    OH / NC
    2017 Prius v wagon
    Here's a pic of the amazon part.
  13. icyrius
    icyrius Active Member
    242
    115
    Florida, USA
    2014 Prius v wagon
    Got mine done today. Love it! Thank you @Centerpunch for your help! Perfect fit.
    Centerpunch and Georgina Rudkus like this.
