Gen 4 Rear Wiper Delete
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Plus IV, Mar 4, 2016.
  1. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    Wanted to share how I completed the rear wiper delete today.
    Removing the hatch panels is pretty easy. Start with the lower panel by giving a little tug to release the clips. Then remove the side panels, the small top panel, and then the larger top panel. You will be left with this...[​IMG]
    Unplug the motor harness. You can zip tie it to the wires so that it doesn't rattle around. Using a 10mm socket, remove the wiper arm from the stem and set aside. Remove the (3) 10mm nuts that hold the motor to the hatch. [​IMG][​IMG]
    Remove the motor and you will be left with a hole in the glass. [​IMG]
    I purchased a 1 3/8" metal hole plug from Lowes. [​IMG]
    I roughed up the metal surface with fine sandpaper and then applied 2 coats of primer. [​IMG]
    I then gave it 3 coats of gloss black automotive paint, letting it dry 15 mins between coats. [​IMG][​IMG]
    Once it was dry, I installed the plug in the hole, bent all the prongs to secure it, and then placed a generous amount of clear silicone around the prongs and interior of the plug. You don't want any water from rain or car washes getting inside.
    I re-installed the hatch panels in the reverse order I took them off. I like the smooth clean look. I never used the wiper so I'm not going to miss it. [​IMG][​IMG]
  2. bigmichaelkim
    bigmichaelkim Member
    70
    US
    Cool thanks for this post! Please let us know if any issues arise.
  3. Mendel Leisk
    42,367
    Does the Eco level rear window not have a hole in the windshield (for the missing wiper), and a plug? In other words just plain glass. Just curious, if the plug would be available with a part number.
  4. Prodigyplace
    12,720
    11,852
    Central Virginia
    If I were doing that i would ask my dealer about the part for the Eco.
  5. Mendel Leisk
    42,367
    Well maybe there is no part, ie: the Eco rear glass doesn't have a hole. That's what I'm wondering. I wouldn't do a mod like this, but just curious.
  6. Jerbear949
    Jerbear949 Member
    61
    42
    Ladera Ranch, CA
    we don't need no stinking rear wipers! nice job senor...
    hugosg9 likes this.
  7. Mendel Leisk
    42,367
    Editorial: should be "steenking".
    Dylan Doxey likes this.
  8. BLITZ XW50
    BLITZ XW50 Member
    91
    81
    Chicago, IL
    Looks good without the rear wiper. Any pictures from a distance?
  9. alexgrigori
    alexgrigori Active Member
    163
    109
    Technology
    Does it improve backward visibility? Motor cover is occupying a bottom corner of the window. Is it possible to straight it up?
    RCO likes this.
  10. ponderosabob
    ponderosabob Junior Member
    Nevada
    Goofy.
    Why not just buy the 2 eco?
  11. Prodigyplace
    12,720
    11,852
    Central Virginia
    Perhaps they wanted the 17" wheels, Softex seats, or some of the other features & options on the 4 Touring. The 2016 Eco did not even have many of the safety features available.
    RCO likes this.
  12. Mendel Leisk
    42,367
    ^ Or the spare.
    I wouldn't do something like this, but the wiper is pretty useless. Maybe good in heavy snow: gives a small clear patch. But, come trade-in time, you've got a chore to restore it to stock. Or if you leave it as-is you confuse/frustrate buyer.
    Kudos to the OP for all the nice clear pics though. (y)
    Plus IV and RCO like this.
  13. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    I'm going to do a DIY on how to install two wipers in the rear. Lol
  14. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    We look forward to hearing all about it when you get back
    Prodigyplace likes this.
  15. Mendel Leisk
    42,367
    A pantograph style wiper would be good for the rear, much better coverage:
    do not know if there's any way it could be done with the current hole location though. Maybe?
  16. UltraJetRefill
    156
    93
    Tucson, AZ
    Funny, it just rained here and I got to use the rear wiper for the first time. My initial thought was, "That's it?" :D
    RCO likes this.
  17. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
    Or buy Prime, though it does not come with 17 inch wheels, it is cheaper than buying Gen4 Touring if you live in NE. ;)
  18. Mendel Leisk
    42,367
    I use the rear wiper occasionally on our 3rd gen, have similar reaction. I suppose it'd be good for snow, it doesn't sweep much of an area though.
    RCO likes this.
  19. jamiec123
    jamiec123 Member
    89
    75
    Ohio
    Very nice write up! I’m going to do this tomorrow as my rear wiper got destroyed in a touch less car was of all things! I know, Wth right. I looked up a new wiper arm and I’m not paying $50 for something I have never used.
    Anyway, what area in Lowe’s can this plug be found?
    RCO likes this.
  20. Plus IV
    Plus IV LowGen4
    452
    399
    Ladera Ranch, Ca
    Four Touring
    You will find it in the nuts and bolts area. It will be in a drawer. There will be all different sizes, both metal and plastic.
    iPhone ?
    jamiec123 likes this.
