Gen 4 Staff Manual (In Japanese) =/ Specs/Design/Other Info
Discussion in 'Gen 4 Prius Main Forum' started by E46Prius, Sep 23, 2015.
  1. DtEW
    DtEW Active Member
    242
    137
    SF Bay Area, CA
    "In addition, a fixed gear second gearset is implemented: the drive motor (MG2) is linked to the front wheel transaxle by means of a second planetary gearset, thereby making it possible to increase the power density of the MG2. This allows for a motor with less torque but higher power (and higher maximum rotary speed)"
    This sounds exactly like the 3rd-gen HSD, not the 4th-gen. The 4th gen has one planetary gearset that is at the heart of the HSD. The 3rd gen has one planetary gearset at the heart of the HSD, and another to connect/reduce the MG2 to the final drive... exactly as described for the RX400h here.
    And you can see in this video:
    The engine front-and center (marked THS II + E-Four) is the RX400h engine. You can see that the engine crankshaft/MG1/MG2 are all coaxial. Close-up detail is seen at the 1:13 mark.
    #161 DtEW, Oct 2, 2015
  2. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    See what your saying editing previous post. Wasn't considering the actual coaxial production.
    Looking at block diagram pg 19 of ref. If you change from ring1 (Ice/mg1) to carrier2 (mg2/output) and instead connect ring1 to ring2 via the counter gear and allow ring2 to rotate then Ice/mg1 and mg2 are parallel and the second gear set can also functions as a reduction gear. Anyway parallel, easier seen in the Ford diagram, gets us away from the mg1 over speed problem and having to friction spin the Ice to prevent it No? Wonder how many % friction that's worth. Higher EV speed as a result too?
  3. rthrglf
    rthrglf Junior Member
    17
    Monterey Park CA
    Does this manual show fuel tank capacity for new Prius?
  4. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    38L for Eco, 45L for models above
  5. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    The Gen4 Staff Manual says the JP E grade has 38 liters and the other JP grade has 43 liters.
    Ken@Japan
  6. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    The Gen4 Staff Manual says the Cd value is 0.24.
    Ken@Japan
    parkerbol and Tideland Prius like this.
  7. cyclopathic
    3,292
    547
    2014 Prius c
    Thanks! So the gains due aero are marginal!
  8. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Really? What the change in frontal area?
  9. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    The Gen4 Staff Manual says the JC08 fuel economy numbers are...
    E grade: 40.0 km/L IW=1310kg and below
    S grade: 37.0 km/L IW=above 1310kg (2WD) 35.0 km/L (4WD)
    A grade: 37.0 km/L IW=above 1310kg (2WD) 35.0 km/L (4WD)
    The Gen3 actual JC08 fuel economy numbers are...
    L grade: 32.6 km/L IW=1310kg and below
    S grade: 30.4 km/L IW=above 1310kg
    G grade: 30.4 km/L IW=above 1310kg
    (note: IW stands for inertia weight of chassis dynamo load on fuel economy testing.)
    The Gen3 Prius EPA unadjusted fuel economy number is 71 mpg ( 30.2 km/L).
    source: http://www3.epa.gov/fueleconomy/fetrends/1975-2014/420r14023a.pdf#page=17
    Ken@Japan
    parkerbol likes this.
  10. cyclopathic
    3,292
    547
    2014 Prius c
    0.48% reduction in frontal area, marginal?
  11. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    The Gen4 Staff Manual says the body size is...
    length: 4540mm +60mm vs Gen3
    width: 1760mm +15mm
    height: 1470mm -20mm
    wheel base: 2700mm no change
    Ken@Japan
  12. cyclopathic
    3,292
    547
    2014 Prius c
    So on JC08 Gen4 is 21.7% better than Gen3? Since JC08 is centered around city cycle, we can expect similar showings on EPA city. Even if highway rating will go up by modest 5% (4% engine efficiency and 2% due to aerodrag) we can expect close to 14% overall rating improvement.
    62 city/ 50 hwy
    57MPG combined??
    #172 cyclopathic, Oct 2, 2015
  13. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Total drag = (Cd) x (Frontal Area of Car)
    Anyone want to calculate the percent decrease in drag?
  14. cyclopathic
    3,292
    547
    2014 Prius c
    Jay wants..
    my back of the napkin calculations show 4% reduction in Cd and 0.5% reduction in frontal area, so 4.5%?
    Keep in mind that EPA is still testing at 55MPH (or rather use in approximation formula), and at that speed less then 60% of drag is generated by aero. 40% tires, and they include A/C and acceleration/deceleration into account. The later hasn't change b/c the weight stayed the same
    #174 cyclopathic, Oct 2, 2015
  15. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    You have missed ...
    20% less friction on the transaxle
    20% less loss on the PCU
    Ken@Japan
  16. Mendel Leisk
    41,456
    My (trivial I know) beef: there's one engine in there. There's not, for example, an internal and an external combustion engine. And I'm not sure what's the alternative to a "combustion" engine. In short: a fluffed-up, three word description, purely so we can turn it into an esoteric, pretentious acronym, of something that used to be just fine with one word: engine. Terse, succinct, what's not to like.
    Oy, ranting.
    (Oh crap, managed to quote myself.)
    #176 Mendel Leisk, Oct 2, 2015
  17. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    I calculate a 7% decrease in total drag with the Gen 4 Prius with the Cd of 0.24 in the Japanese staff manual:
    Gen 3: 0.25 x 6.2 sq. ft = 1.55
    Gen 4: 0.24 x 6.0 sq. ft = 1.44
  18. cyclopathic
    3,292
    547
    2014 Prius c
    I've used the "conservative" numbers.
    I agree with you if 57MPG confirmed most of the gains come from these, not from engine and aerodrag. And that should have the biggest impact on city cycle.
    #178 cyclopathic, Oct 2, 2015
  19. cyclopathic
    3,292
    547
    2014 Prius c
    I do not see frontal area change by that much -0.2sq ft.
  20. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
