Gen 4 to Gen 3, what you need to know
Discussion in 'Gen 3 Prius Technical Discussion' started by cnc97, Jul 18, 2018.
  1. jan jurnecka
    jan jurnecka New Member
    tucson, az
    I
    1. not subject to the gen. 3 head gasket issues
    2. $500-$1000 cheaper than a gen 3 used engine with similar mileage, (supply and demand: the need for engines is greater the older the car)
  2. Mendel Leisk
    41,486
    Maybe yes, maybe no: if you retain 3rd gen EGR (safest bet), and IF clogging EGR is a factor in the head gasket failures, then that may still be an issue. Just keep on top of EGR cleaning.
    Ragingfit and Foxglove like this.
  3. christian cox
    christian cox Member
    115
    ohio
    Whats the difference between a short block and a standard block ? And you can reuse a standard head with a short block? On that note could I use a standard gen 3 head on a gen 4 block? Or are they too different? I thought I saw the water jackets are different, if so which head gasket should you use gen3 or 4??
  4. Mendel Leisk
    41,486
    A short block just means everything but the cylinder head, everything below the head gasket. It's an odd expression, but it's well-known. Doesn't mean it's height is less somehow. If your pistons or crankshaft is toast for example, you can just get a new short block, assemble with your current head.
