Gen 5 17" wheel covers
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Mar 14, 2023.
  1. Gokhan
    Gokhan Senior Member
    4,655
    1,866
    Paramount CA
    Your thoughts on how they look? Is one better-looking than the other?
    The one on the left is possibly for Prius Prime PHEV, and the one on the right is for Prius HEV.
    Left photo:
    Manufacturer option
    ● 195/60R17 tires & 17×6½J
    Chill wheel (resin full cap
    [with dark gray metallic paint])
    Right photo:
    Aluminum wheel (resin full cap
    [Dark Gray Metallic +
    with matte black paint)
    #1 Gokhan, Mar 14, 2023
  2. Salamander_King
    Salamander_King Senior Member
    10,975
    8,867
    New England
    According to Toyota's published tire and wheel spec sheet, the left is a Maker Option wheel and cover combination that is available for both Prius HEV (Grade ZG) and PHEV (Grade Z). (Highlighted options marked with triangle icon on the left) It is a standard for the lowest trim level (Grade X) model with a steel wheel. Your translation made a mistake, it is not a "Chill Wheel", it says "Steel Wheel". The cover shown on the right is listed only for Prius HEV (Grade U) and is for an Aluminum wheel. Since they come as a Wheel and Cover combination and the one on the right of the photo is only available for the Aluminum wheel and the left one is for the Steel wheel, I am not even sure if they are interchangeable.
    I think Grade U and X which come with smaller 1.8L engines are for subscription and fleet-only models. My take is that it is a down-grade option for upper trims of HEV (Grade Z and G) and for PHEV (only Grade Z available).
    Note that I have no idea how US models will be equipped though.
    #2 Salamander_King, Mar 14, 2023
    Tideland Prius and Gokhan like this.
  3. Mountaindewsprite
    Mountaindewsprite New Member
    LA
    2023 Prius
    the one on the left is on the japanese prius and it has the old steel wheels instead of the right one that has the aloy under
    Gokhan likes this.
  4. Gokhan
    4,655
    1,866
    Paramount CA
    Do you speak Japanese? Is there a link for this?
  5. Salamander_King
    10,975
    8,867
    New England
    Gokhan likes this.
  6. Gokhan
    4,655
    1,866
    Paramount CA
    It is so strange that none of the translators I tried was able to translate チール properly.
    Why would they use an alloy 17" wheel on the Prius HEV but a steel 17" wheel on the Prius PHEV—strange.
  7. Salamander_King
    10,975
    8,867
    New England
    That's because AI is missing the first letter of this word. It says スチール. The first letter is on the top line.
    Mendel Leisk and Gokhan like this.
  8. Gokhan
    4,655
    1,866
    Paramount CA
    Yes, I just discovered that on my own as well when I looked at your spec file.
  9. Gokhan
    4,655
    1,866
    Paramount CA
    Then, these are the questions remaining:
    Will Prius Prime SE in the US come with steel wheels or aluminum wheels?
    Will Prius Prime SE in the US come with glossy black trim or matte black trim?
    There is only one Prius PHEV trim in the Japan (PHEV Z); so, we can't really compare it to the US trims.
  10. Salamander_King
    10,975
    8,867
    New England
    US model SE trim with a 17" wheel may come with the alloy wheel. The Steel wheel is standard on the GradeX in Japan which is the fleet-only lowest trim level in Japan. The alloy 17" wheel is available only for GradeU as the standard. My understanding is that this is for the subscription trim. Basically, they don't want to sell upper trims with 17" wheels, you have to special order it to downgrade to 17" wheels and can get only steel wheels, so my feeling is that no one is going to buy 17" wheels for G and Z grade Prius HEV or for Z grade PHEV.
    Gokhan likes this.
  11. Gokhan
    4,655
    1,866
    Paramount CA
    It says "17-inch alloy wheels with wheel covers" here.
    Poised for performance: 2023 Toyota Prius Prime revealed—Toyota USA newsroom
    Salamander_King likes this.
  12. Salamander_King
    10,975
    8,867
    New England
    Yes, I see it. US SE trim probably comes with the same wheel for Japan Grade U HEV trim. And no steel wheel with cover.
    Gokhan likes this.
