Gen 5 LE wiring diagram.
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by patmine23, Mar 16, 2024.
  1. patmine23
    patmine23 Junior Member
    2023 Prius
    Does anyone know if there is a wiring diagram available for this model trim?
  2. ChapmanF
    18,733
    What Toyota generally does is one wiring diagram for the model and year. Where there are differences in the wiring between specific trims, the diagram shows all the versions, with numbered (*) marks next to the wires, and matching numbered notes on the page.
    Toyota Service Information and Where To Find It | PriusChat
    patmine23 and wrtboy168 like this.
  3. Hammersmith
    Hammersmith Senior Member
    2,371
    2,420
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Pay for access to Toyota TIS(Technical Information Service) at techinfo.toyota.com
    $25 - two days
    $95 - one month
    $505 - one year
    If you've never read Toyota wiring diagrams before, I'd suggest paying for a month. But if you're already comfortable with them, two days should be enough. You can always print to pdf anything you need, though you'll lose all the hyperlinks.
    Also, all the trims are the same wiring diagram. In fact, even the HEV and PHEV are usually the same diagram unless there are major differences(in those cases, the diagrams have a (HEV) or (PHEV) after them).
    purplePriii and patmine23 like this.
  4. Mendel Leisk
    42,058
    Take out a short-term subscription at Toyota Tech Info.
    What @Hammersmith said.
    patmine23 likes this.
  5. ChapmanF
    18,733
    The link given in #2 contains what Hammersmith said and also a good deal that Hammersmith didn't say, about alternate ways of accessing the material and how to make the most effective use of it.
  6. patmine23
    2023 Prius
    Thank you very much for the info. The main thing I was interested in was the differences between each trim level. For adding things the car did not come with stock.
