Gen 5 Prius and Prius Prime owners thread
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Jan 3, 2023.
  1. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    It’s gorgeous! Thanks for the upbeat review especially comparing it to the Gen 4. I parked next to a Gen 4 today and FINALLY thought to myself that I made the right decision passing on the Gen 4. Then I got the text tonight saying my Gen 5 Prius will be on its way soon. Fingers crossed I can see the displays okay.
    Sounds like you’re really enjoying it. Have fun and keep us posted!
  2. Hammersmith
    Hammersmith Senior Member
    2,499
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    You have to give the wheel just a little bit of input once in awhile to keep it happy. On empty road, highway driving, I can hook one finger near the bottom of the wheel and just give little pulses now and then.
    Perpetual Waffle and Preebee like this.
  3. Ansari
    Ansari Junior Member
    43
    2023 Prius
    Do we have to follow engine break-in period and change early oil too?
  4. CruisnGrrl
    CruisnGrrl Active Member
    151
    128
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    No, my first oil change is scheduled for November or 8000KM which ever comes first.
    Because of the CVT and the battery the engine doesn't stay in a constant use.
    The computer has now upped my electric distance to 63.8KM
    Sarge likes this.
  5. Hammersmith
    2,499
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Manual:
    For the first 200 miles (300 km):
    - Avoid sudden stops.
    For the first 600 miles (1000 km):
    - Do not drive at extremely high speeds.
    - Avoid sudden acceleration.
    - Do not drive continuously in low gears.*
    - Do not drive at a constant speed for extended periods.
    No early oil change recommended by the manual. Toyota has also reduced the list of extreme service conditions for the 6m/5k oil changes. Short trips in freezing weather and long periods of idling/slow driving(taxi/delivery) have been removed, leaving only towing*/car topper/heavy loads and dusty/rough roads.
    Personally, I'm doing the first oil change at 750 miles and 6m/5k oil changes for the extra safety net. But I plan to hold onto the car for 10+ years and 150k+ miles. If you plan to only hold onto the car for less than five years, you may find that using just the recommended service schedule more appealing.
    *obviously Toyota must have boilerplate sections of the manual, as neither of these really apply to Priuses
    model464, Sarge and mikey_t like this.
  6. Ansari
    43
    2023 Prius
    Thank you for your detail message and advise. I will follow your advise and have plan to keep it 10+ years by the will of GOD.
    Do we have to use 0w 16 grade oil? or I can use 0w 20 too? Is Valvoline a good brand?
  7. Hammersmith
    2,499
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Don't use 0W-20. If you were stuck somewhere and that's all you could get, you could use it for 5k miles, but it's not good to use it for anything other than an emergency. The engine was designed for 0W-16, so that's what you should use.
    Any of the major brands are fine as long as you stick to the maintenance schedule. I prefer Pennzoil Platinum(though I'd use Pennzoil Ultra Platinum if it was available in 0W-16) followed by Mobile 1, but Valvoline is fine if you have a reason for buying it(low price or easy availability or something). Since you plan to own the car for 10+ years, I'd suggest 6m/5k instead of 1y/10k, but that's up to you. It also depends on your climate and your driving habits. At the very least, DO NOT go beyond one year between oil changes and DO NOT go beyond 10,000 miles between changes.
    The priority chain is something like this(best to worst):
    1. High quality oil + frequent changes
    2. Mid quality oil + frequent changes
    3. High quality oil + long changes
    4. Mid quality oil + long changes
    5. Low quality oil + frequent changes
    6. Low quality oil + long changes
    1&2 are for if you want to keep the car in the best shape possible or own it for 10+ years. 3&4 are perfectly fine for 3-5 years, but you might start seeing more problems at 150k+ miles. 5&6 should be avoided unless the car is on its last legs anyway and is destined for the scrap yard within a year or three.
    At least that's my opinion. Take it as you will.
    mikey_t and Sarge like this.
  8. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    100%. Simply put, if you put out the money for a new car, why try to scrimp a few dollars a few times a year that could result in repairs later that cost thousands (or void warranty, etc.). Just follow the maintenance recommendations from the manufacturer. (y)
    model464, samsprius1 and Tom_06 like this.
  9. Gokhan
    Gokhan Senior Member
    6,717
    2,672
    Paramount CA
    There is no reason to use a thicker oil. SAE 0W-16 is your best friend because in a PHEV and also in an HEV, the engine oil hardly warms up with many start–stop cycles.
  10. Ansari
    43
    2023 Prius
    Excellent advise. I agree with you. Thank you
  11. model464
    model464 Junior Member
    27
    23
    Colorado
    2023 Prius Prime
    SE
    I wonder, does the optimum point for the break-in oil change actually depend on ICE miles? i.e., should it be at a slightly later mileage since so much distance is covered with the ICE off?
    I'm going to do a break-in oil change on my Prime SE and initially planned on 1,000 miles but am reconsidering that after seeing ~70% "EV driving ratios" in HV mode (though I think that's based on time, not miles).
    More than one person online says the directives relating to speed are actually trying to avoid high or constant RPMs, which I'm monitoring via Torque Pro, so I'm making sure to vary RPMs and keep them under 3000.
    #291 model464, Jun 20, 2023
  12. Numtini
    Numtini Member
    91
    94
    Cape Schrod
    2023 Prius Prime
    XSE
    I assumed it was about the ICE and ran the first 600 in HV mode just to be safe.
  13. Gokhan
    6,717
    2,672
    Paramount CA
    Toyota Genuine Motor Oil (TGMO) is made by ExxonMobil. Mobil 1 is excellent. Pennzoil Platinum is a close second in non-OEM oils. Pennzoil Platinum Ultra is iffy with some strange specs. Valvoline is good. TGMO is excellent—I would prefer it to Mobil 1 because it is made according to what Toyota demands, which are: high moly content (fuel efficiency), high boron content (sludge dispersant), and polyol ester (POE) in base oil (to prevent dirty or clogged rings that could increase oil consumption). None of the non-OEM oils have these properties.
    So, TGMO is a clear winner unless it is to costly to source. I buy three TGMO oil changes, tire rotations, and multipoint inspections at West Coast Toyota of Long Beach for $149.95, which is an excellent deal.
    https://www.westcoasttoyotalb.com/advantagecare/
    soft_r and Exerted like this.
  14. nagrath
    nagrath Member
    145
    49
    Putnam County, New York
    2023 Prius Prime
    XSE
    I took delivery of a 2023 Reservoir Blue Prius Prime XSE about a week and a half ago, and here are some of my impressions.
    Things I love:
    The look - the car is just stunning, and looks like a sports car. The blue color is gorgeous (as is the gray, which was my first choice). Details, lights, typefaces, all are really nicely executed. It is an understated, sleek, sporty car.
    EV Mode - quiet, fast, with good range - I have gotten 38-44 miles on a charge, even with the 19" wheels.
    Hybrid mode: Pickup, steering, braking, all better than my Gen 2 and Gen 3. Fun to drive!
    The interior - I thought I would hate it, but it really does look sharp. It doesn't seem to get excessively hot, despite being black, and the red trim is nice. Seats are comfortable, and after a few drives, I no longer feel "closed in" compared to my Gen 3- in fact, it feels pretty open and airy.
    The safety features - all work great, and all have ample controls to limit the beeping and annoyance. And most can even be shut off. The cruise control is the best I have encountered.
    Things I am not very fond of:
    Rear visibility - terrible
    The wheels/Tires- The 19" wheels look great, but lower the mpg, have expensive super low profile tires which look like they would be useless in the snow and have a rougher ride. And I don't even see snow tires in that size available locally yet.
    Steering wheel/ Instrument cluster - it's nice having the display on the driver's side again, but it is not easy to adjust the steering wheel so you can see the the whole display, and not have the wheel very low and close to your legs. A larger steering wheel could have fixed that (so you could look through it). I was told by the dealer that they were originally planning to use a yoke instead of a wheel but they decided that was too "radical".
    Multimedia screen: the choices made here are terrible. There is no "home" screen with full useful information (like my wife's Rav4) - something showing clock, temp, MPG, range, current radio station/song, trip odometer, and such things would be a great default screen. It would also be nice to be able to hide invalid sources like Apple or Amazon Music so you don't have to scroll through them each time. Ability to reorder favorites would be nice, too, unless I missed how to do that.
    Android Car Play works fine, but those screens are annoying, too, so I don't use it unless I want the Nav function. But everything works, and it just seems like it could have used a little more UX research. I also miss having an easy display of my average MPG between chosen resets (It will show per-trip but I have not found the average-between-resets like my old Priuses and the Rav4 Hybrid have)
    Noise: in EV mode there is a little road noise; in hybrid mode, there is definitely engine noise, maybe more than my last 2 Priuses (Gen 2 and 3) I think. Not terrible, but quieter would be better.
    Things I despise:
    Rear cargo cover - there is this super annoying, cheap-looking butterfly cover that cannot be retracted. So if you want to put anything into the trunk taller than the cover, you have to remove and stow it. I hope someone develops an aftermarket solution with a normal window-shade type cover like previous Priuses.
    All in all, though, I am really enjoying the car !
    mikey_t, Downrange, Ansari and 5 others like this.
  15. bisco
    52,899
    great write up, thank you!
    nagrath likes this.
  16. Trollbait
    12,832
    The bZ4x and Lexus RZ have this type of instrument cluster. The RZ will be getting the yoke as an option. All the reviews I've seen of Toyota's yoke love it.
  17. Numtini
    Numtini Member
    91
    94
    Cape Schrod
    2023 Prius Prime
    XSE
    One of my few complaints about the car is getting into it because the bottom of the wheel pokes at my legs at first and a yoke would solve that.
  18. bisco
    52,899
    Will be interesting to see how the general public takes to a yoke
  19. Roqu3
    Roqu3 Member
    92
    63
    Lima
    2019 Prius c
    Maybe in the future they will use the one from Lexus that is just by wire
    mountaineer likes this.
  20. Gokhan
    6,717
    2,672
    Paramount CA
