Gen 5 Prius and Prius Prime owners thread
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Jan 3, 2023.
  1. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    Thanks, this is very interesting.
    So, the 19" tires are really a mess. The ride is too harsh with them, and they are recommending a lower air pressure to make up for it.
    The 19" tires are nothing but a marketing gimmick. They hurt the ride, fuel economy, BEV range, load capacity, etc. It is a really bad move by Toyota.
    #141 Gokhan, Mar 20, 2023
    GuyLR and CCS like this.
    52,891
    thanks CCS!
    my gen3 measures 51" diagonally, and 38" at the widest part of the bottom, which is a couple inches above the floor.
    CCS likes this.
  3. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    great thread and great pics throughout. I picked up my 2023 XLE last week and I have a few things that I could mention. The trunk area seems a LOT smaller than previous years. I'm also not a fan of the styrofoam inserts that raise the trunk floor up ~6(?) inches. If you remove the inserts the floor that sits on them isn't strong enough to support itself. Just seems like a really bad design to hold an emergency compressor and a slime canister. My Ioniq that I just sold had this "no spare, use this instead" idea and I think it's really just the manufacturers cheapening out. I really hope that an aftermarket trunk floor is invented or I might create one myself.
    The entertainment system. Mine only came with the standard 8" screen although I would have preferred the larger screen. I just didn't want AWD. I have no need for it in South TX. Also, this built in wifi thing is a waste. When you get into the car, you have to sign a phone in or maps won't run at all. I could be wrong though. Still trying to experiment with it when the wife doesnt have the car. lol....
    I'm not a fan of the speed limit sign always on the dashboard and turning red when I exceed what the computer says it is. I'm hoping I can turn that off somehow.
    I'll post more when I determine more but that's the initial (bad) things. There's too many GOOD things to list!!!!
  4. Troubadour
    Troubadour Junior Member
    Washington DC
    Thanks for the readout. Very informative. How did you feel about the rear view out of the back (not when backing out necessarily, but when on the highway?
  5. bisco
    52,891
    this small trunk thing is really putting me off
    HoustonEvolution likes this.
  6. Gokhan
    6,715
    2,672
    Paramount CA
    Could you check and report the maximum cold pressure on the 19" tires? 51 psi or 36 psi maximum cold pressure stamped on it? A picture of the tire would be nice, too.
  7. Mendel Leisk
    42,372
    even if the bolt pattern matched, the OD’s are waaay different.
    where’s your old car; maybe reunite them?
  8. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Rides a tiny bit firmer but it's not harsh by any means unless you're the type that drives with your pinky in the air. They will handle better, not to mention they look way better. Buy a lexus if you want a plush ride.
    it's 51..
    Tideland Prius and Gokhan like this.
  9. PhoS
    PhoS Active Member
    258
    210
    Nowhere
    2023 Prius
    Limited AWD-e
  10. Gokhan
    6,715
    2,672
    Paramount CA
    Thanks! I like to inflate them to 41/40 psi or even 43/42 psi. It gives much better fuel economy and probably reduces the wear on the tire as well.
  11. DKTVAVKMC
    DKTVAVKMC Member
    Huntington Beach, Orange County, SoCal, US
    2023 Prius
    I've been running at side walls psi. I put in my daughter 51 F and 49 R. My own MB 50 F and 52 R. Never had any problem whatsoever with more mileage and less wear.
    Gokhan likes this.
  12. Mendel Leisk
    42,372
    I’ve got reservations about running higher pressures; probably a tough audience, but: tires are part of the suspension system, absorb shocks, from potholes, speed bumps etcetera. I’d think running max sidewall pressure (when you’re not doing due so temporarily due to being near load limit), you’re accelerating wear of wheel bearings and suspension.
    #152 Mendel Leisk, Mar 22, 2023
    Tideland Prius and Louis19 like this.
  13. bisco
    52,891
    at least the wheels look way better than the LE
    PhoS likes this.
  14. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    It doesnt bother me at all. The Ioniq I had before didnt have that great of a view either.
    Something else to mention is that this car sits LOW. It seems like you're crawling into a Corvette. The Aframe/roofline is something you really have to duck down to avoid. Btw, I'm only 5'8". I can only imagine what kind of limbo a person +6' has to do!
    Troubadour and bisco like this.
  15. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    THANKS!!!!
    I read the manual on our first trip and didnt catch that.
    The small trunk thing is annoying but that rediculous styrofoam platform thing is absurd. Wth were they thinking???
    #155 HoustonEvolution, Mar 22, 2023
  16. Mendel Leisk
    42,372
    And underneath, a spare tire well. :rolleyes:
    As long as customers are snapping them up, paying extra to scalpers, erm I mean dealerships, and then cobbling spare tire solutions, Toyota will have no motivation to reinstate it.
  17. bisco
    52,891
    i wonder if their really popular cars still have spare tires?
  18. Mendel Leisk
    42,372
  19. bisco
    52,891
    interesting list, i wonder if it's correct and complete nd up to date, i don't trust dealers.
    our 13 hycam has a full spare, but that may have gone away with battery reconfigurations, idk.
    ah, ijust noticed may of 18 at the bottom.
  20. Troubadour
    Washington DC
    Thanks. Yes, mine hasn't arrived yet, but, I sat in one and it is low. I'm no spring chicken, so I have to get in and out carefully. Btw, how did you like your Ioniq? Why did you sell it?
