Gen 5 Tailgate Opens by Itself
Discussion in 'Gen 5 Prius Main Forum' started by Philip Frame, May 18, 2024.
  1. Philip Frame
    Philip Frame Junior Member
    San Francisco Bay Area
    2023 Prius Prime
    XSE Premium
    Love my Gen 5 prime, but once every month or so, the tailgate opens by itself. I'm not touching the key fob, it just does it spontaneously.
    This problem is rare, but any vehicle with a power tailgate is at risk. It's also been reported in Chevy, GMC, Ford, Mercedes and BMW vehicles. And those are the ones I know about. Nobody seems to know what causes it, let alone how to fix it, other than disabling it. Since it was designed as a power tailgate, it's a real pain to open it manually.
    The only thing I can think of is some stray signal from some electronic device that just happens to be at the same frequency in the neighborhood is setting it off.
    If that's the case, would it be possible to change the frequency/code the vehicle and key fob use, so as to prevent this from happening again?
  2. Paul Gregory
    Paul Gregory Senior Member
    2,328
    610
    Alberta
    2024 Prius Prime
    XSE
    You lost me at "rare."
  3. Gokhan
    Gokhan Senior Member
    6,685
    2,651
    Paramount CA
    It could be a defective fob. Put it inside a tin box when you are home so that you block the radio signal and see what happens.
    briidea key-fob protector, RFID signal-blocking Faraday box, key safe for car key, black
    52,742
    try the other fob for awhile?
  5. Mendel Leisk
    42,223
    And you've lost me: if it happens say only once a month it's ok?
    mountaineer likes this.
  6. Philip Frame
    2023 Prius Prime
    XSE Premium
    Out of thousands of vehicles of various makes, only a handful have reported this problem on the internet. I believe that's the definition of "rare".
  7. Philip Frame
    2023 Prius Prime
    XSE Premium
  8. Philip Frame
    2023 Prius Prime
    XSE Premium
    I don't think it's the fob. When I'm at home, the fob is out of range and can't open the tailgate.
  9. Philip Frame
    2023 Prius Prime
    XSE Premium
    I never said or implied it was ok. In fact the purpose of this thread is to fix the problem. If it was "ok", why bother?
  10. Paul Gregory
    2,328
    610
    Alberta
    2024 Prius Prime
    XSE
    It's not about me thinking it's OK or not.
    I'll worry about it if it happens.
    Or if someone is hurt by it.
  11. Gokhan
    6,685
    2,651
    Paramount CA
    Well, perhaps try putting the car in a Faraday cage then. LOL
    It could also be a defective part in the car.
  12. Paul Gregory
    2,328
    610
    Alberta
    2024 Prius Prime
    XSE
    I'm guessing that Toyota is engineering a new key fob with better security.
    They'll probably have us turn in the original for two new ones.
