Gen 5 tire sizes
Discussion in 'Gen 5 Prius Main Forum' started by Hammersmith, Nov 19, 2022.
  1. Tideland Prius
    16,680
    That still requires manufacturers to actually produce that tire size.
    Mendel Leisk and farmecologist like this.
  2. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    BTW - on the oil type for the new Prius. It is 0W16...See pic below. Pic was taken from one of the walkthrough videos. (y)
    Trollbait and Tideland Prius like this.
  3. shoreview
    shoreview Junior Member
    Illinois
    There's just nothing in any common tire available in North America in narrower than a 205 for 17, or a 225 for 19. The 205-225 difference would presumably explain MPG issues one is likely to encounter with a 19, but narrower than 205 in the 17 would strike me as really problematic for both handling and tire choice, and something of a dealbreaker in buying the car. Hope this gets cleared up. Also a fair bit depends on the diameter of the wheel; if it's 26.something inches as I've seen suggested elsewhere, a 215/55R17 would be a fairly mainstream fit but the 205/55R17 might be on the small side diameter wise and there doesn't seem to be a 205/60R17. And the 205/50R17 that I suspect would fit OK on a current Prius or anything else designed for 25 inch diameter wheel/tire combinations will be too small on this new one.
    reallyreal likes this.
  4. PriusPeep
    PriusPeep Member
    127
    79
    New Jersey
    I want the trim with the larger screen. That means I have to get the Prius with the ridiculous and unnecessary 19" tires.
    Why, Toyota? I drive the 2017 Prius 3 with 15" tires. It drives great. I have driven in snow countless times. It's never been a problem unless it's a blizzard and, even then, you can drive if the streets are plowed.
    I don't like the extra weight on 19' tires and the likely increased road noise.
  5. Rmay635703
    Rmay635703 Senior Member
    2,701
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    If Toyota wanted stupid tire sizes they should have stuck with exactly the i3 size,
    It’s a massive kick in the nuts using what will be a $300 tire and hardly available
    Tideland Prius likes this.
  6. Mendel Leisk
    42,345
    Stick with what you've got?
  7. Trollbait
    12,826
    They are larger diameter than the current Prius tires, which could actually help with efficiency. They are the same width as the current car, so snow handling shouldn't have changed much.
    The i3 size is unique. Sounds like the size on the new Prius is popular in Japan.
    drash likes this.
  8. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    This is my understanding as well - I find it hard to believe Toyota would have used this size if it was a (significant) hit on efficiency.
    The only concern is availability and possible cost if there are limited options, but I would think that Toyota would have explored / planned for this with tire manufacturers in a major market like the US (and by extension, Canada...)… Right? Right?? o_O
  9. Christopher O'Brien
    153
    79
    Toronto
    2013 Prius Plug-in
    I don't like really low-profile tires like on the 19" wheels. Surely ride comfort suffers, plus the wheel wells looked overstuffed with wheel. Haven't seen a photo of the 17" wheels yet, but in the Gen 5's wheel wells they might end up looking a bit understuffed like the 15" wheels on the present Gen 4. Maybe 18" wheels would do the trick—better looking and more ride comfort. Any thoughts?
    drash likes this.
  10. Tideland Prius
    16,680
    Comparing the new tyres with the old:
    195/50R19 = 97.5mm sidewall
    215/45R17 = 96.75mm sidewall
    195/60R17 = 117.0mm sidewall
    195/65R15 = 126.75mm sidewall
    It'll definitely have a stiffer ride with less cushion but that can always be adjusted with the spring and damper settings.
    drash likes this.
  11. Prashanta
    Prashanta Active Member
    292
    242
    Technology
    Could you explain how the 17" tire has a smaller sidewall than than 19" one? Are the tire diameters different? What good reason is there for having different diameter tires?
  12. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Well for the sidewall,that is a 0.75mm difference or 1/32in difference ......pretty close.:rolleyes:
  13. Mendel Leisk
    42,345
    Yes.
    Well, nominal size, ie 17” vs 19”, yes. Outside Diameter, they’re reasonably close to each other. Have to be, for ride height, odometer, speedometer, “gearing”, and so on.
    Tideland Prius and Trollbait like this.
  14. CamryDriver
    CamryDriver Active Member
    541
    391
    Arkansas
  15. Mendel Leisk
    42,345
    I meant these two (5th gen) sizes need to be reasonably close:
    195/50R19
    195/60R17
    Trollbait likes this.
  16. Trollbait
    12,826
    @Tideland Prius had a typo, the 17in rim aspect ratio is 60 or 65. The overall diameter is 27in for the combo; 0.3in larger than the 19in. With the tire sizing system, getting the same overall diameter is difficult if just changing the aspect.
  17. Tideland Prius
    16,680
    I thought it’s 195/60R17 and 195/50R19??
    @Mendel Leisk and @CamryDriver have good posts explaining it.
    I was comparing the new tyre specification to the Gen 4 specifications.
    Honestly, I think they went for looks for the 19” but also didn’t want to give up fuel efficiency which is why they kept the 195mm width tyres rather than widen it to something like a 225 or 235mm width tyre that is typical of a 19”.
  18. Trollbait
    12,826
    I, and apparently @Prashanta , took your post format to be grouping the wheel sizes together by model year, not small or large equipped wheel sizes of each gen together.
    Current car has 15" and 17" wheel sizes. The new has 17" and 19". The 17" overlap requires paying closer attention to the tire size to differentiate which car is being discussed.
    The new Prius tires are 2 inches larger in diameter than the old one's. That was likely chosen for efficiency. Larger rims are nearly always about style. Maybe that tire size is more common in Japan. Wider tires would hurt efficiency, but there could be clearance issues too. NA might get a wider tire, if the 195 size is an issue.
    The 19in wheel might be too narrow for 225 to 235 tires for those thinking of swapping.
    Tideland Prius and Mendel Leisk like this.
  19. Mendel Leisk
    42,345
    Too, maybe we need to wait for official 5th gen tire specs. If these are the correct sizes, there's a not insignificant 1/2" difference in the OD's (Outside Diameters):
    195/50R19: 26.7"
    195/60R17: 26.2"
    OD's determined using this calculator:
    Tire Size Calculator
  20. Trollbait
    12,826
    A 195/65R17 would be 27 inches.
    CarBuzz reported the rim width as 7 inches.
